Canon Support for ME20F-SH | Canon U.S.A., Inc.
![](/etc.clientlibs/canon/clientlibs/clientlib-base/resources/images/image/canon-image-default.webp)
ME20F-SH
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
Camera Connect
image.canon
SELECT ERROR CODE
Sensor | 35mm Full Frame CMOS (16:9 extract) |
Total Pixels | Approx. 2.59M (2160 x 1200) |
Effective Pixels | Approx. 2.26M (2000 x 1128) |
Resolution | 1920 x 1080, 1280 x 720 |
Pixel Size | 19um x 19um |
Min. Sub. Illum. | 0.0005 lux or less (at 75dB, F1.2, 1/30s, 50IRE) |
Color Filter Array | RGB Bayer |
Canon EF Mount | Cinema Lock type |
Canon EF Lenses | Select EF, EF-S and Cinema (EF-mount) Lenses |
GEN LOCK | Black burst or Tri-level reference |
Microphone | 3.5mm stereo mini jack (plug-in power mic supported) |
Remote Control | Remote A: 2.5mm stereo mini jack (Canon protocol) Remote B: Circular 8-pin for RS-422 (Canon protocol) |
3G/HD-SDI | Terminal 1 (On screen display optional) Terminal 2 (Clean out only) Bit Depth: YCbCr422 10bits (effective bits: 8) Frame Rates: 1920 x 1080: 59.94P/59.94i/50P/50i/29.97P/25P/23.98P 1280 x 720: 59.94P/50P/29.97P/25P/23.98P * Cannot set frame rate and output size separately by SDI and HDMI. |
HDMI | Terminal 1 (On screen display optional) Bit Depth: RGB444, YCbCr422, YCbCr444 (effective bits: 8 for each format) Frame Rates: 1920 x 1080: 59.94P/59.94i/50P/50i/29.97P/25P/23.98P 1280 x 720: 59.94P/50P/29.97P/25P/23.98P * Cannot set frame rate and output size separately by SDI and HDMI. ** 640x480: 59.94P & 768x576: 50P will be output when connected with a monitor that support 480P and 576P inputs. Cannot be set from the menu and the on screen display will not show. |
Auto Exposure (AE) | Iris, Gain, Shutter and ND filter operating together (Cannot set auto/manual separately) AE shift/AE response selectable AGC limit can be set from 36dB to Off/75dB (3-dB intervals) |
Manual | Iris: 1/2 stops (push auto iris can be set to an assign button) Gain: 0dB to 75dB @ 3-dB intervals (approx. ISO 4,560,000 equivalent at 75dB) Shutter: 1/3 to 1/2000 (1/4 stops) |
Focus Control | One-Shot AF (can be set to an assign button) |
W/B | AWB (2,000K-15,000K), Daylight, Tungsten, Custom Set A, Custom Set B |
Optical FiltersND filters: | ND filters: 1/8 & 1/64 Built-in (auto or motorized manual) IR cut filter: On/Off (motorized manual) |
Digital Teleconverter | 2x, 3x, 4x |
Custom Picture Setting | EOS Standard, Wide DR, Canon Log, crispImg2, Custom 1-6 |
Other Functions | Auto black balance, color bar, test tone (interlocking with color bar), assign buttons, peripheral illumination correction, focus limit, crop for EF-S Lens, scan reverse, flicker reduction, noise reduction, time display, hour meter |
Terminals | XLR 4-pin or terminal block 2-pin jack |
Input | DC +11V , +17V |
Consumption | Power Consumption Approx. 12W (body only) |
Operating Temperature | Approx. 0 - 40 °C (32-104 °F) |
Dimensions | 4.0 x 4.6 x 4.4 in. (102 x 116 x 113mm) |
Weight | Approx. 2.2 lbs. (1,000g) |
Included in the Box | ME200S-SH, 2-pin DC Power Contact |
Related Accessories | Canon RC-V100 Remote Controller, Canon EF Lenses |
ADDITIONAL SUPPORT
CONTACT US
