Canon Support for LX-P5510 Pigment Inkjet Label Printer | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 07.26.24
File Size 6.16 MB
Date 07.26.24
File Size 7.88 MB
Products Windows 10 Windows 11
Printer
Printing Method Pigment-based Inkjet
Ink Cartridges 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Shop Compatible Ink
Print Resolution 1200x1200 dpi
Max Print Speed First Print Out Time: 4" x 3" Label: 10 seconds or less
Default Print Speed: 300 mm/second (11.8 inches/second)
Range: 50 - 300 mm/s
Preset Options: 300 mm/s, 200 mm/s, 150 mm/s, 120 mm/s, 100 mm/s, 90 mm/s, 80 mm/s, 70 mm/s, 60 mm/s, 50 mm/s1
Supported Media Types Label Roll Media (with Roll Holder) & Label Fanfold Media (IJ Coated: Matte Paper, Matte Synthetic, Gloss Paper)
Media Capacity Roll Media: Outer Diameter: Up to 200 mm
Core/Inner Diameter: Up to 76.2 mm
Fanfold Media: Media Height: Up to 850 mm
Media Size & Thickness Media Size: Width: 25.4 - 120.0 mm (Including Liner)
Length: 6.0 - 500.0 mm
Media Thickness: 0.145 - 0.255 mm
Maximum Printable Area Width: Up to 105.9 mm (with AIS On)
Length: 3.0 - 497 mm
Minimum Margin Top/Bottom: 1.5 mm
Left/Right: 2.7 mm (including Liner, with AIS On)
Product Life Approx. 6 Million Sheets / 5 Years2
General
Output per Cartridge Set Approx. 34,000 Sheets2
Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 240 ml
Maintenance Cartridge WT-X401 Maintenance Cartridge
Approx. 100,000 Sheets
Operational Method LCD: No
Buttons/LEDs: 4 Buttons / 8 LEDs
Connectivity USB 2.0, Ethernet (10/100/1000 Base-T), RS- 232C (For External Devices)
OS Compatibility Windows 11 (64bit), Windows 10 (64/32 bit)3
Operating Environment Temperature: 41° - 95°F (5° - 35°C)
Humidity: 10 - 90% RH (Non-Condensing)
Options CU-L02 Auto Cutter Unit Module
RH-L03 Roll Holder Module
Rewinder
Power Consumption (approx.) Maximum: Approx. 268 W
Operating: Approx. 29 W
Electrical AC 100-240V, 50/60Hz
Acoustic Information Operating Noise (Max.): 55dB or less
Standby Noise: 35dB or less4
Warranty One-Year On-Site Limited Warranty5
Dimension (W x D x H) 15.2 (W) x 22.4 (D) x 15.5 (H)
Weight 55.1 lbs.6
CANON LX-SERIES LABEL PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon LX-D5500/LX-P5510/LX-P1300/LX-D1300 Inkjet Label Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the Canon LX-D5500 LX-P5510/LX-P1300/LX-D1300 Inkjet Label Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty does not cover consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
For remote diagnostic assistance for operation and support of the Product, call:
  • Your local Service Provider; or
  • 1-855-852-2666, Monday through Friday from 8 a.m. to 8 p.m. ET (excluding Canon holidays).
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON), INCLUDING NON-CANON INK CARTRIDGES OR REFILLED INK CARTRIDGES, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Canon is a registered trademark of Canon Inc.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
