Canon Support for imageRUNNER ADVANCE DX C5740i | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE DX C5740i | |
MAIN UNIT | |
TYPE | ColorLaserMultifunctional |
CORE FUNCTIONS | Standard:Print,Copy,Scan,Send,Store Optional: Fax |
PROCESSOR | 1.75GHzDualCoreProcessor |
CONTROL PANEL | 10.1"TFTLCDWSVGAColorFlat-panel |
MEMORY | 4.0GBRAM |
HARD DISK DRIVE | Standard:250GB/Maximum:1TB |
PRINT RESOLUTION | 1200x1200 |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T,WirelessLAN(IEEE802.11b/g/n)Others Standard:USB2.0(Host)x1,USB3.0x1(Host),USB2.0x1(Device) Optional:SerialInterface,CopyControlInterface |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard:1,200Sheets Maximum:6,350Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual550-sheetPaperCassettes,100-sheetStackBypass Optional: Dual550-SheetPaperCassettes(CassetteFeedingUnit-AM1),2,450-SheetHighCapacityPaperCassette(HighCapacityCassetteFeedingUnit-A1),2,700-SheetPaperDeck(PaperDeckUnit-F1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard:250Sheets Maximum: 3,450Sheets(withExternalFinisherandCopyTray) |
FINISHING CAPABILITIES | Standard:Collate,Group WithOptions:Collate,Group,Offset,Staple,Saddle-Stitch,HolePunch,EcoStaple,StapleOnDemand |
SUPPORTED MEDIA TYPES | Multi-PurposeTray: Thin,Plain,Recycled,Color,Heavy,Coated,Tracing,Bond,Transparency,Label,Pre-punched,Letterhead,Tab,Envelope PaperCassettes: Thin,Plain,Recycled,Color,Heavy,Bond,Transparency,Pre-punched,Letterhead,Envelope1 |
SUPPORTED MEDIA SIZES | UpperCassette: Letter,Executive,Statement-R,Envelope[No.10(COM10),DL,ISO-C5],CustomSize(3-7/8"x5-7/8"to11-3/4"x8-1/2") LowerCassette: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],CustomSize(3-7/8"x7-1/8"to12"x18") Multi-PurposeTray: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],EnvelopeCustomSize(3-7/8"x3-7/8"to12-5/8"x18"),CustomSize/FreeSize(3-7/8"x5-1/2"to12-5/8"x18") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14lb.Bondto140lb.Index(52to256g/m2) StackBypass:14lb.Bondto110lb.Cover(52to300g/m2) Duplexing:14lb.Bondto80lb.Cover(52to220g/m2) |
PRINT/COPY SPEED (BW AND COLOR) | Up to 40 ppm (Letter); Up to 24 ppm (Letter-R); Up to 23 ppm (Legal); Up to 22 ppm (11" x 17") |
WARM-UP TIME | FromPowerOn: Approx.10Seconds2 FromSleepMode: Approx.10Seconds3 QuickStartupMode: Approx.4Seconds4 |
DIMENSIONS (W x D x H) | 24-3/8"x28-1/2"x36-7/8"(620x722x937mm)5 |
INSTALLATION SPACE (W x D x H) | Basic:42-5/8"x45-3/4"(1,083x1,162mm)(RightCoverOpenwithMulti-purposetrayextended+CassetteDrawersOpen) FullyConfigured: 73-1/2"x45-3/4"(1,866x1,162mm)(BookletFinisher-Y1withtheextensiontrayextended+PaperDeckUnit-F1+CassetteDrawersopen) |
WEIGHT | Approx.310.9lb.(141kg)6 |
PRINT SPECIFICATIONS | |
STANDARD PAGE DESCRIPTION LANGUAGES | UFRII,PCL6,AdobePS3 |
SUPPORTED FILES | PDF,TIFF,JPEG,EPS,7XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | ArangeofstandardandoptionalsoftwareandMEAP-basedsolutions(includingAirPrint,Mopria,Universal Print by Microsoft, CanonPRINTBusiness,anduniFLOWOnline)areavailabletoprovideprintingfrommobiledevicesorinternet-connecteddevicesandcloud-basedservicesdependingonyourrequirements.Pleasecontactyoursalesrepresentativeforfurtherinformation. |
FONTS | PCL:93Roman,10Bitmapfonts,2OCRfonts,AndaléMonoWTJ/K/S/T(Japanese,Korean,SimplifiedandTraditionalChinese),8BarcodeFonts9 PS:136Roman |
OPERATING SYSTEM 10 | UFRII/PS: Windows®7/8.1/10/Server2008/ Server2008R2/Server2012/Server2012R2/Server2016/Server2019,MacOSX(10.10orlater) PCL:Windows®7/8.1/10/Server2008/ Server2008R2/Server2012/Server2012R2/Server2016/Server2019 PPD:Windows®7/8.1/10,MacOSX(10.9orlater) |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 4.1 seconds (BW)/ 6.1 seconds (Color |
COPY RESOLUTION (dpi) | 600x600 |
MULTIPLE COPIES | Upto999 |
MAGNIFICATION | 25%-400%(1%Increments) |
PRESET REDUCTION / ENLARGEMENT | 25%,50%,64%,73%,78%,100%(1:1),121%,129%,200%,400% |
SCAN SPECIFICATIONS | |
TYPE | Single-PassDuplexingAutomaticDocumentFeeder |
DOCUMENT FEEDER PAPER CAPACITY | Upto200Sheets(20lb.Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11"x17",Legal,Letter,Letter-R,Statement,Statement-R,CustomSize:2-3/4"x5-1/2"to12"x17" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL) Double-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL) |
PLATEN ACCEPTABLE ORIGINALS | Sheet,Book,3-DimensionalObjects |
PULL SCAN | ColorNetworkScanGear2forbothTwainandWIA SupportedOS:Windows®7/8.1/10/Server2008/Server2008R2/Server2012/Server2012R2/Server2016 |
SCAN RESOLUTION (dpi) | ScanforCopy: 600x600 ScanforSend:(Push)600x600(SMB/FTP/WebDAV/ IFAX),(Pull)600x600 ScanforFax:600x600 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | Arangeofsolutionsisavailabletoprovidescanningtocompatiblemobiledevicesandcertaincloud-basedservicesdependingonyourrequirements. |
SCAN SPEED (LETTER) | Single-sidedScanning: 135/135(300dpi),80/80(600dpi), Double-sidedScanning: 270/270(300dpi),160/90(600dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Standard:E-mail/InternetFAX(SMTP),SMB3.0,FTP,WebDAV,MailBox Optional: SuperG3FAX,IPFax |
ADDRESS BOOK | LDAP(2,000)/Local(1,600)/SpeedDial(200) |
SEND RESOLUTION | Push:Upto600x600 Pull:Upto600x600 |
COMMUICATION PROTOCOL | File:FTP(TCP/IP),SMB3.0(TCP/IP),WebDAV Email:SMTP,POP3 |
FILE FORMAT | Standard:TIFF,JPEG,PDF(Encrypted,Compact,Searchable,ApplyPolicy,OptimizeforWeb,UserSignature,PDFA/1-b,LimitedColor,DeviceSignature,UserSignature),XPS(Compact,Searchable,DeviceSignature,UserSignature),OfficeOpenXML(PowerPoint,Word) |
FAX SPECIFICATIONS | |
MODEM SPEED | SuperG3:33.6Kbps G3: 14.4Kbps |
COMPRESSION METHOD | MH,MR,MMR,JBIG |
RESOLUTION | 400x400,200x400,200x200,200x100 |
SENDING / RECORDING SIZE | Statement-Rto11"x17" |
FAX MEMORY | Upto30,000Pages(2,000jobs) |
SPEED DIALS | Max.200 |
GROUP DIALS / DESTINATIONS | Max.199Dials |
SEQUENTIAL BROADCAST | Max.256Addresses |
MEMORY BACKUP | Yes |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100UserIn-boxes,1MemoryRXIn-box,50ConfidentialFaxIn-boxes,Maximum10,000Pages(2,000jobs)Stored |
ADVANCED BOX | CommunicationProtocol:SMBorWebDAV SupportedClientPC: Windows(Windows8.1/10) ConcurrentConnections(Max.) SMB: 64 WebDAV: 3 |
ADVANCED BOX AVAILABLE DISC SPACE | Approx.16GB(StandardHDD) Approx.480GB(WithOptional1TBHDD) |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: UniversalLoginManager,uniFLOWOnlineExpress,11UserAuthentication,DepartmentIDAuthentication,AccessManagementSystem,DeviceandFunctionLevelLog-in Optional:uniFLOW |
DATA | Standard:TrustedPlatformModule(TPM),HardDiskPasswordLock,HardDiskDriveErase,MailBoxPasswordProtection,HardDiskDriveEncryption(FIPS140-2Validated),VerifySystematStartup,3McAfeeEmbeddedControl Optional:HardDiskDriveMirroring,IEEE2600.2CommonCriteriaCertification,DataLossPrevention(RequiresuniFLOW) |
NETWORK | Standard: EncryptedSecurePrint,IP/MacAddressFiltering,IPsec,TLSEncryptedCommunication(v1.0/1.1/1.2/1.3),SNMPV3.0,IEEE802.1X,IPv6,SMTPAuthentication,POPAuthenticationbeforeSMTP,S/MIME,SIEMIntegration |
DOCUMENT | Standard: SecureWatermark,SecurePrint,AdobeLiveCycle®RightsManagementES2.5Integration,EncryptedPDF,EncryptedSecurePrint,DigitalSignature UserSignature |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50to86ºF Humidity:20to80%RH(RelativeHumidity) |
POWER REQUIREMENTS | 110-127V, 60Hz, 10A |
POWER CONSUMPTION | Maximum: Approx.1,800W Standby:Approx.63.1W12 SleepMode:Approx.0.8W13 TypicalElectricityConsumption(TEC)Rating14 0.57kWh |
STANDARDS | ENERGYSTAR®Certified RatedEPEAT®Gold |
CONSUMABLES | |
TONER | GPR-55 Toner15 |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 69,000 Images |
FOOTNOTES | |
ADDITIONAL SUPPORT
CONTACT US
