Canon Support for imageRUNNER ADVANCE DX 6000i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
MAIN UNIT
TYPE MonochromeLaserMultifunctional
CORE FUNCTIONS Standard:Print,Copy,Scan,Send,Store
Optional: Fax
PROCESSOR 1.75GHzDualCoreProcessor
CONTROL PANEL10.1"TFTLCDWSVGAColorFlat-panel
MEMORY4.0GBRAM
HARD DISK DRIVEStandard:250GB/Maximum:1TB
INTERFACE CONNECTION Network: 1000Base-T/100Base-TX/10Base-T,WirelessLAN(IEEE802.11b/g/n)
Others
Standard:USB2.0(Host)x1,USB3.0x1(Host),USB2.0x1(Device)
Optional: CopyControlInterface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard:1,200Sheets
Maximum:6,350Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: Dual550-sheetPaperCassettes,100-sheetStackBypass
Optional: Dual550-SheetPaperCassettes(CassetteFeedingUnit-AM1),2,450-SheetHighCapacityPaperCassette(HighCapacityCassetteFeedingUnit-A1),2,700-SheetPaperDeck(PaperDeckUnit-F1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)Standard:250Sheets
Maximum: 3,450Sheets(withExternalFinisherandCopyTray)
FINISHING CAPABILITIESStandard: Collate,Group
WithOptions:Collate,Group,Offset,Staple,Saddle-Stitch,HolePunch,EcoStaple,StapleOnDemand
SUPPORTED MEDIA TYPESMulti-PurposeTray: Thin,Plain,Recycled,Color,Heavy,Coated,Tracing,Bond,Transparency,Label,Pre-punched,Letterhead,Tab,Envelope
PaperCassette: Thin,Plain,Recycled,Color,Heavy,Bond,Transparency,Pre-punched,Letterhead,Envelope1
SUPPORTED MEDIA SIZES
UpperCassette: Letter,Executive,Statement-R,Envelope[No.10(COM10),DL,ISO-C5],CustomSize(3-7/8"x5-7/8"to11-3/4"x8-1/2")
LowerCassette: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],CustomSize(3-7/8"x7-1/8"to12"x18")
Multi-PurposeTray: 12"x18",11"x17",Legal,Letter,Letter-R,Executive,Statement,Statement-R,Envelope[No.10(COM10),Monarch,DL,ISO-C5],EnvelopeCustomSize(3-7/8"x3-7/8"to12-5/8"x18"),CustomSize/FreeSize(3-7/8"x5-1/2"to12-5/8"x18")
SUPPORTED MEDIA WEIGHTSCassettes: 14lb.Bondto140lb.Index(52to256g/m2)
Multi-PurposeTray: 14lb.Bondto110lb.Cover(52to300g/m2)
Duplexing:14lb.Bondto80lb.Cover(52to220g/m2)
PRINT/COPY SPEED Upto60ppm(Letter),Upto36ppm(Letter-R),
Upto34ppm(Legal),Upto32ppm(11"x17")
WARM-UP TIMEFromPowerOn: Approx.10Seconds2
FromSleepMode: Approx.10Seconds3
QuickStartupMode: Approx.4Seconds4
DIMENSIONS (W x D x H) 24-3/8"x28-1/2"x36-7/8"(620mmx722mmx937mm)5
INSTALLATION SPACE (W x D x H) Basic: 42-5/8"x45-3/4"(1083mmx1162mm)(RightCoverOpenwithMulti-PurposeTrayextended+CassetteDrawersOpen)
FullyConfigured: 73-1/2"x45-3/4"(1866mmx1162mm)(BookletFinisher-Y1withtheExtensionTrayExtended+PaperDeckUnit-F1+CassetteDrawersOpen)
WEIGHTApprox.280.0lb(127kg)6
PRINT SPECIFICATIONS
PRINT RESOLUTION 1200x1200
STANDARD PAGE DESCRIPTION LANGUAGESUFRII,PCL®6,Adobe®PS®3
SUPPORTED FILE TYPES FOR DIRECT PRINTPDF,TIFF,JPEG,EPS,7XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES ArangeofstandardandoptionalsoftwareandMEAP-basedsolutions(includingAirPrint,Mopria,Universal Print by Microsoft, CanonPRINTBusiness,anduniFLOWOnline)areavailabletoprovideprintingfrommobiledevicesorInternetconnecteddevicesandcloud-basedservicesdependingonyourrequirements.Pleasecontactyoursalesrepresentativeforfurtherinformation.
FONTS PCL: 93Roman,10Bitmapfonts,2OCRfonts,AndaléMonoWTJ/K/S/T(Japanese,Korean,SimplifiedandTraditionalChinese),8BarcodeFonts9
PS: 136Roman
OPERATING SYSTEM 10 UFRII/PS:Windows®7/8.1/10/Server2008/Server2008R2/Server2012/Server2012R2/ Server2016/Server2019,MacOSX(10.10orlater) PCL:Windows®7/8.1/10/Server2008/Server2008R2/Server2012/Server2012R2/ Server2016/Server2019
PPD: Windows®7/8.1/10,MacOSX(10.9orlater)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME Approx.2.9secondsorless
COPY RESOLUTION (dpi)600x600
MULTIPLE COPIESUpto9,999
MAGNIFICATION 25%-400%(1%Increments)
PRESET REDUCTION / ENLARGEMENT 25%,50%,64%,73%,78%,100%(1:1),121%,129%,200%,400%
SCAN SPECIFICATIONS
TYPE Single-PassDuplexingAutomaticDocumentFeeder
DOCUMENT FEEDER PAPER CAPACITY Upto200Sheets(20lb.Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11"x17",Legal,Letter,Letter-R,Statement,Statement-R,CustomSize:2-3/4"x5-1/2"to12"x17"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL)
Double-SidedScanning: 13.3lb.Bondto80lb.Cover(50to220gsm)(BW,CL)
PLATEN ACCEPTABLE ORIGINALS Sheet,Book,3-DimensionalObjects
PULL SCAN ColorNetworkScanGear2forbothTwainandWIA
SupportedOS:Windows®7/8.1/10/Server2008/Server2008R2/Server2012/Server2012R2/Server2016
SCAN RESOLUTIONScanforCopy: 600x600
ScanforSend: (Push)600x600(SMB/FTP/WebDAV/ IFAX),(Pull)600x600
ScanforFax: 600x600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES Arangeofsolutionsisavailabletoprovidescanningtocompatiblemobiledevicesandcertaincloud-basedservicesdependingonyourrequirements.
SCAN SPEED (LETTER)Single-SidedScanning: 135/135(300dpi),80/80(600dpi),
Double-SidedScanning: 270/270(300dpi),160/90(600dpi)
SEND SPECIFICATIONS
DESTINATION Standard:E-mail/InternetFAX(SMTP),SMB3.0,FTP,WebDAV,MailBox
Optional: SuperG3FAX,IPFax
ADDRESS BOOK LDAP(2,000)/Local(1,600)/SpeedDial(200)
SEND RESOLUTION Push:Upto600x600
Pull: Upto600x600
COMMUICATION PROTOCOLFile:FTP(TCP/IP),SMB3.0(TCP/IP),WebDAV
Email: SMTP,POP3
FILE FORMAT TIFF,JPEG,PDF(Compact,Searchable,Applypolicy,OptimizeforWeb,PDF/A-1b,Trace&Smooth,Encrypted,DeviceSignature,UserSignature),XPS(Compact,Searchable,DeviceSignature,UserSignature),OfficeOpenXML(PowerPoint,Word)
FAX SPECIFICATIONS
MODEM SPEED SuperG3:33.6Kbps
G3:14.4Kbps
COMPRESSION METHOD MH,MR,MMR,JBIG
RESOLUTION 400x400,200x400,200x200,200x100
SENDING / RECORDING SIZE Statement-Rto11"x17"
FAX MEMORY Upto30,000Pages(2,000jobs)
SPEED DIALSMax.200
GROUP DIALS / DESTINATIONS Max.199Dials
SEQUENTIAL BROADCASTMax.256Addresses
MEMORY BACKUPYes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)100UserIn-boxes,1MemoryRXIn-box,50ConfidentialFaxIn-boxes,Maximum30,000Pages(2,000jobs)Stored
ADVANCED BOX CommunicationProtocol: SMBorWebDAV
SupportedClientPC: Windows(Windows8.1/10)
ConcurrentConnections(Max.)
SMB: 64
WebDAV: 3
ADVANCED BOX AVAILABLE DISC SPACEApprox.16GB(StandardHDD)
Approx.480GB(WithOptional1TBHDD)
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: UniversalLoginManager,uniFLOWOnlineExpress,11UserAuthentication,DepartmentIDAuthentication,AccessManagementSystem,DeviceandFunctionLevelLog-in
Optional:uniFLOW
DATA Standard: TrustedPlatformModule(TPM),HardDiskPasswordLock,HardDiskDriveErase,MailBoxPasswordProtection,HardDiskDriveEncryption(FIPS140-2Validated),VerifySystematStartup,McAfeeEmbeddedControl
Optional:HardDiskDriveMirroring,IEEE2600.2CommonCriteriaCertification,DataLossPrevention(RequiresuniFLOW)
NETWORKStandard:EncryptedSecurePrint,IP/MacAddressFiltering,IPsec,TLSEncryptedCommunication(v1.0/1.1/1.2/1.3),SNMPV3.0,IEEE802.1X,IPv6,SMTPAuthentication,POPAuthenticationbeforeSMTP,S/MIME,SIEMIntegration
DOCUMENTStandard:SecureWatermark,SecurePrint,AdobeLiveCycle®RightsManagementES2.5Integration,EncryptedPDF,EncryptedSecurePrint,DigitalSignature UserSignature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50to86ºF
Humidity:20to80%RH(RelativeHumidity)
POWER REQUIREMENTS 110-127V,60Hz,11.5A
POWER CONSUMPTION Maximum:Approx.1,800W
Standby:Approx.55.3W12
SleepMode:Approx.0.8W13
TypicalElectricityConsumption(TEC)Rating14 0.83kWh
STANDARDS ENERGYSTAR®Certified
RatedEPEAT®Gold
CONSUMABLES
TONER
GPR-55 Toner Black
TONER YIELD (ESTIMATED @ 6% COVERAGE)
Black: 57,500 Images
FOOTNOTES
  1. EnvelopeFeederAttachment(standard)isrequired.
  2. Timefromdevicepower-onuntilcopyready(notprintreservation).
  3. TimefromexitingSleepmodetowhenprintingisoperational.
  4. Timefromdevicepower-ontowhenthecopyiconappearsandisenabledtooperateonthetouchpaneldisplay.
  5. IncludesmainunitandeitherCassetteFeedingUnit-AM1,HighCapacityCassetteFeedingUnit-A1,orCabinetType-N.
  6. Includesmainunit,consumables,andCassetteFeedingUnit-AM1.
  7. EPScanbeprinteddirectlyonlyfromtheRemoteUserInterface.
  8. RequirestheoptionalPCLInternationalFontSet-A1.
  9. RequirestheoptionalBarcodePrinterKit-D1.
  10. Otheroperatingsystemsandenvironments,includingAS/400,UNIX,Linux,andCitrixmaybesupported.Someofthesesolutionsarechargeable.SAPDeviceTypesareavailableviatheSAPMarketPlace.Formoreinformation,contactyoursalesrepresentative.
  11. Nochargeforthissolution;however,activationisrequired.
  12. ReferenceValue(measuredoneunit).
  13. 0.8WSleepmodenotavailableinallcircumstancesduetocertainsettings.
  14. BasedonENERGYSTARProductSpecificationforImagingEquipmentVersion3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
