Canon Support for imageRUNNER ADVANCE DX 4735i | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
imageRUNNER ADVANCE DX 4700 Series Brochure
imageRUNNER ADVANCE DX 4735i | |
MAIN UNIT | |
TYPE | Monochrome Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | 1.75 GHz Dual Core Processor |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Touch-panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB Maximum: 1 TB |
PRINT RESOLUTION | 1200 dpi x 1200 dpi |
INTERFACE CONNECTION | Network Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Optional: Bluetooth Low Energy Others Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Copy Control Interface |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 1,200 Sheets Maximum: 6,350 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Two 550-sheet Paper Cassettes, 100-sheet Stack Bypass Optional: Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 250 Sheets Maximum: 3,350 Sheets (with Buffer Pass-N1 + Staple Finisher-Y1 or Booklet Finisher-Y1) |
FINISHING CAPABILITIES | Standard: Collate, Group With Finishers: Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand |
SUPPORTED MEDIA TYPES | Upper/Lower Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched Multi-purpose Tray: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Label, Envelope |
SUPPORTED MEDIA SIZES | Upper Cassette: Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") Lower Cassette: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17"), Envelope1: [No.10 (COM10), Monarch, DL, ISO-C5] Multi-purpose Tray: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size/Free Size (3-7/8" x 5-7/8" to 11-3/4" x 17") |
SUPPORTED MEDIA WEIGHTS | Upper/Lower Cassette: 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2) Multi-purpose Tray: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Duplexing: 16 lb. Bond to 28 lb. Bond (60 to 105 g/m2) |
PRINT/COPY SPEED | Up to 35 ppm (Letter), Up to 32 ppm (Letter-R), Up to 25 ppm (Legal), Up to 22 ppm (11" x 17") |
WARM-UP TIME | From Power On: Approx. 24 Seconds2 From Sleep Mode: Approx. 10 Seconds3 Quick Startup Mode: Approx. 4 Seconds4 |
DIMENSIONS (W x D x H) | With Platen Cover-Y2: 24" x 28-1/8" x 32-3/8" (608 mm x 713 mm x 822 mm) With Single Pass DADF-C1: 24" x 28-1/2" x 36-3/4" (608 mm x 722 mm x 932 mm) With DADF-BA1: 24" x 28-3/8" x 36-1/2" (608 mm x 719 mm x 926 mm) |
INSTALLATION SPACE (W x D x H) | Basic: 44" x 45-5/8" (1,116 x 1,160 mm) (with Platen Cover-Y2 + Multi-purpose Tray open/extension tray extended + Paper Cassette open) 44" x 46" (1,116 x 1,169 mm) (with Single Pass DADF-C1 + Multi-purpose Tray open/ extension tray extended + Paper Cassette open) 44" x 45-7/8" (1,116 x 1,166 mm) (with DADFBA1 + Multi-purpose tray open/extension tray extended + Paper Cassette open) Fully Configured: 71-3/8" x 46" (1,811 x 1,169 mm) (with Single Pass DADF-C1 + Paper Deck Unit-F1 + Booklet Finisher-Y1 with extension tray extended and Saddle unit drawn) 71-3/8" x 45-7/8" (1,811 x 1,166 mm) (with DADF-BA1 + Paper Deck Unit F1 + Booklet Finisher-Y1 with extension tray extended and Saddle unit drawn) |
WEIGHT5 | With Platen Cover-Y2: Approx. 165.3 lb. (75 kg) With Single Pass DADF-C1:Approx. 193.8 lb. (87.9 kg) With DADF-BA1:Approx. 179.5 lb (81.4 kg) |
PRINT SPECIFICATIONS | |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
SUPPORTED FILE TYPES FOR DIRECT PRINT | PDF, TIFF, JPEG, EPS, XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information. |
FONTS | PCL Fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),6 Barcode Fonts7 PS Fonts: 136 Roman |
OPERATING SYSTEM 8 | UFRII/PS: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Serve 2012 R2/ Server 2016/Server 2019, Mac OS X (10.10 or later) PCL: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019 PPD: Windows® 7/8.1/10, Mac OS X (10.9 or later) |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 3.8 seconds |
COPY RESOLUTION (dpi) | 600 x 600 |
MULTIPLE COPIES | Up to 9,999 Copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTION / ENLARGEMENT | 25%, 50%, 64%, 73%, 78%, 100%(1:1), 121%, 129%, 200%, 400% |
SCAN SPECIFICATIONS | |
TYPE | Optional Single Pass Duplexing Automatic Document Feeder, Duplexing Automatic Document Feeder, or Platen Cover |
DOCUMENT FEEDER PAPER CAPACITY | Single Pass DADF: Up to 200 Sheets DADF: Up to 100 Sheets |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single Pass DADF-C1 Single-sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 g/m2) Double-sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 g/m2) DADF-BA1 Single-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2) (CL) Double-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2) (CL) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects |
PLATEN SUPPORTED MEDIA SIZE | UP to 11-3/4" x 17" (297 mm x 431.8 mm) |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016 |
SCAN RESOLUTION | Push: Up to 600 x 600 Pull: Up to 600 x 600 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements. |
SCAN SPEED (LETTER) | Single Pass DADF-C1 Single-sided Scanning BW/Color: 135 ipm (300 dpi)/80 ipm (600 dpi) Double-sided Scanning BW/Color: 270 (300 dpi), 160 (600 dpi) DADF-BA1 Single-sided Scanning BW/Color: 70 (300 dpi), 51 (600 dpi) Double-sided Scanning BW/Color: 35 (300 dpi), 35.5 (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Standard: E-mail/Internet FAX (SMTP), SMB 3.0, FTP, WebDAV, Mail Box Optional: Super G3 Fax, IP Fax |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | Push: Up to 600 x 600 Pull: Up to 600 x 600 |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB 3.0 (TCP/IP), WebDAV Email: SMTP, POP3 |
FILE FORMAT | TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize for Web, PDF/A-1b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word) |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages (2,000 Jobs) |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored (2,000 Jobs Stored) |
ADVANCED BOX | Communication Protocol: SMB or WebDAV Supported Client PC: Windows (Windows 8.1/10) Concurrent Connections (Max.) SMB: 64 WebDAV: 3 (Active Sessions) |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (With Optional 1 TB HDD) |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOW Online Express,9 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW |
DATA | Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control10 Optional: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86ºF Humidity: 20 to 80% RH (Relative Humidity) |
POWER REQUIREMENTS | 110-127V, 60Hz, 10.4A |
POWER CONSUMPTION | Maximum: Approx. 1,500 W Standby: Approx. 39 W11 Sleep Mode: Approx. 0.9 W12 Typical Electricity Consumption (TEC) Rating:13 4751i: 0.71 kWh / 4745i: 0.62 kWh / 4735i: 0.51 kWh / 4725i: 0.34 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold |
CONSUMABLES | |
TONER | GPR-57 Toner Black |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | Black: 42,100 Images |
FOOTNOTES | |
