Canon Support for imageRUNNER ADVANCE DX 4735i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE DX 4700 Series Brochure
MAIN UNIT
TYPE Monochrome Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSOR 1.75 GHz Dual Core Processor
CONTROL PANEL10.1" TFT LCD WSVGA Color Touch-panel
MEMORY3.0 GB RAM
HARD DISK DRIVEStandard: 250 GB
Maximum: 1 TB
PRINT RESOLUTION 1200 dpi x 1200 dpi
INTERFACE CONNECTION Network
Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: Bluetooth Low Energy
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 1,200 Sheets
Maximum: 6,350 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: Two 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)Standard: 250 Sheets
Maximum: 3,350 Sheets (with Buffer Pass-N1 + Staple Finisher-Y1 or Booklet Finisher-Y1)
FINISHING CAPABILITIESStandard: Collate, Group
With Finishers: Collate, Group, Offset, Staple, Saddle Stitch, Hole Punch, Eco Staple, Staple On Demand
SUPPORTED MEDIA TYPESUpper/Lower Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched
Multi-purpose Tray: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Label, Envelope
SUPPORTED MEDIA SIZES
Upper Cassette: Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Lower Cassette: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17"), Envelope1: [No.10 (COM10), Monarch, DL, ISO-C5]
Multi-purpose Tray: 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size/Free Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
SUPPORTED MEDIA WEIGHTSUpper/Lower Cassette: 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2)
Multi-purpose Tray: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing: 16 lb. Bond to 28 lb. Bond (60 to 105 g/m2)
PRINT/COPY SPEED Up to 35 ppm (Letter), Up to 32 ppm (Letter-R), Up to 25 ppm (Legal), Up to 22 ppm (11" x 17")
WARM-UP TIMEFrom Power On: Approx. 24 Seconds2
From Sleep Mode: Approx. 10 Seconds3
Quick Startup Mode: Approx. 4 Seconds4
DIMENSIONS (W x D x H) With Platen Cover-Y2: 24" x 28-1/8" x 32-3/8" (608 mm x 713 mm x 822 mm)
With Single Pass DADF-C1: 24" x 28-1/2" x 36-3/4" (608 mm x 722 mm x 932 mm)
With DADF-BA1: 24" x 28-3/8" x 36-1/2" (608 mm x 719 mm x 926 mm)
INSTALLATION SPACE (W x D x H) Basic: 44" x 45-5/8" (1,116 x 1,160 mm) (with Platen Cover-Y2 + Multi-purpose Tray open/extension tray extended + Paper Cassette open) 44" x 46" (1,116 x 1,169 mm) (with Single Pass DADF-C1 + Multi-purpose Tray open/ extension tray extended + Paper Cassette open) 44" x 45-7/8" (1,116 x 1,166 mm) (with DADFBA1 + Multi-purpose tray open/extension tray extended + Paper Cassette open) Fully Configured: 71-3/8" x 46" (1,811 x 1,169 mm) (with Single Pass DADF-C1 + Paper Deck Unit-F1 + Booklet Finisher-Y1 with extension tray extended and Saddle unit drawn) 71-3/8" x 45-7/8" (1,811 x 1,166 mm) (with DADF-BA1 + Paper Deck Unit F1 + Booklet Finisher-Y1 with extension tray extended and Saddle unit drawn)
WEIGHT5With Platen Cover-Y2: Approx. 165.3 lb. (75 kg)
With Single Pass DADF-C1:Approx. 193.8 lb. (87.9 kg)
With DADF-BA1:Approx. 179.5 lb (81.4 kg)
PRINT SPECIFICATIONS
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, Adobe® PS® 3
SUPPORTED FILE TYPES FOR DIRECT PRINTPDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES A range of standard and optional software and MEAP-based solutions (including AirPrint, Mopria, Universal Print by Microsoft, Canon PRINT Business, and uniFLOW Online) are available to provide printing from mobile devices or internet-connected devices and cloud-based services depending on your requirements. Please contact your sales representative for further information.
FONTS PCL Fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),6 Barcode Fonts7
PS Fonts: 136 Roman
OPERATING SYSTEM 8 UFRII/PS: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Serve 2012 R2/ Server 2016/Server 2019, Mac OS X (10.10 or later)
PCL: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/ Server 2016/Server 2019
PPD: Windows® 7/8.1/10, Mac OS X (10.9 or later)
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME As fast as 3.8 seconds
COPY RESOLUTION (dpi)600 x 600
MULTIPLE COPIESUp to 9,999 Copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTION / ENLARGEMENT 25%, 50%, 64%, 73%, 78%, 100%(1:1), 121%, 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE Optional Single Pass Duplexing Automatic
Document Feeder, Duplexing Automatic
Document Feeder, or Platen Cover
DOCUMENT FEEDER PAPER CAPACITY Single Pass DADF: Up to 200 Sheets
DADF: Up to 100 Sheets
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single Pass DADF-C1
Single-sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 g/m2)
Double-sided Scanning: 13.3 lb. Bond to 80 lb. Cover (50 to 220 g/m2)
DADF-BA1
Single-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2) (CL)
Double-sided Scanning: 13.3 lb. Bond to 34 lb. Bond (50 to 128 g/m2) (BW), 17 lb. Bond to 34 lb. Bond (64 to 128 g/m2) (CL)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects
PLATEN SUPPORTED MEDIA SIZE UP to 11-3/4" x 17" (297 mm x 431.8 mm)
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows® 7/8.1/10/Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTIONPush: Up to 600 x 600
Pull: Up to 600 x 600
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)Single Pass DADF-C1
Single-sided Scanning BW/Color: 135 ipm (300 dpi)/80 ipm (600 dpi)
Double-sided Scanning BW/Color: 270 (300 dpi), 160 (600 dpi)
DADF-BA1
Single-sided Scanning BW/Color: 70 (300 dpi), 51 (600 dpi)
Double-sided Scanning BW/Color: 35 (300 dpi), 35.5 (600 dpi)
SEND SPECIFICATIONS
DESTINATION Standard: E-mail/Internet FAX (SMTP), SMB 3.0, FTP, WebDAV, Mail Box
Optional: Super G3 Fax, IP Fax
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION Push: Up to 600 x 600
COMMUICATION PROTOCOLFile: FTP (TCP/IP), SMB 3.0 (TCP/IP), WebDAV
Email: SMTP, POP3
FILE FORMAT TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize for Web, PDF/A-1b, Trace & Smooth, Encrypted, Device Signature, User Signature), XPS (Compact, Searchable, Device Signature, User Signature), Office Open XML (PowerPoint, Word)
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 Pages (2,000 Jobs)
SPEED DIALSMax. 200
GROUP DIALS / DESTINATIONS Max. 199 Dials
SEQUENTIAL BROADCASTMax. 256 Addresses
MEMORY BACKUPYes
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored (2,000 Jobs Stored)
ADVANCED BOX Communication Protocol: SMB or WebDAV
Supported Client PC:
Windows (Windows 8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACEApprox. 16 GB (Standard HDD)
Approx. 480 GB (With Optional 1 TB HDD)
MEMORY MEDIAStandard: USB
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Universal Login Manager, uniFLOW Online Express,9 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
Optional: uniFLOW
DATA Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control10
Optional: Hard Disk Drive Mirroring, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORKStandard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication (v1.0/1.1/1.2/1.3), SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, S/MIME, SIEM Integration
DOCUMENTStandard: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signature, User Signature
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86ºF
Humidity: 20 to 80% RH (Relative Humidity)
POWER REQUIREMENTS 110-127V, 60Hz, 10.4A
POWER CONSUMPTIONMaximum: Approx. 1,500 W
Standby: Approx. 39 W11
Sleep Mode: Approx. 0.9 W12
Typical Electricity Consumption (TEC) Rating:13 4751i: 0.71 kWh / 4745i: 0.62 kWh / 4735i: 0.51 kWh / 4725i: 0.34 kWh
STANDARDSENERGY STAR® Certified
Rated EPEAT® Gold
CONSUMABLES
TONER
GPR-57 Toner Black
TONER YIELD (ESTIMATED @ 6% COVERAGE)
Black: 42,100 Images
FOOTNOTES
  1. Envelope Feeder Attachment-D1 is required.
  2. Time from device power-on, until copy ready (not print reservation).
  3. Time from exiting Sleep mode to when printing is operational.
  4. Time from device power on to when the copy icon appears and is enabled to operate on the touch panel display.
  5. Includes consumables.
  6. Requires the optional PCL International Font Set-A1.
  7. Requires the optional Barcode Printer Kit-D1.
  8. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  9. No charge for this solution; however activation is required.
  10. Requires Unified Firmware Platform v3.9 or greater.
  11. Reference Value (measured one unit).
  12. 0.9 W sleep mode not available in all circumstances due to certain settings.
  13. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Title Service Notice: Google Termination of Support for Google Cloud Print will be ending December 31, 2020.
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
