Canon Support for imageRUNNER ADVANCE C250iF | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Model Name imageRUNNER ADVANCE C250iF
Type Color Digital Multifunction Imaging System
Functions Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3&trade;), Fax (Up to 1 Line), Scan, Send
Operation Panel 7" WVGA Full-Color TFT Screen
Image Server Memory Standard: 2 GB RAM
Maximum: 2 GB RAM
Hard Disk Drive Standard: 80 GB
Maximum: 80 GB
Network Interface Connection Ethernet 10/100/1000Base-TX
Other Interface USB 2.0 x3 (Host), USB 2.0 (Device)
Special Media Support Thin [16 lb. Bond (60 to 63 g/m2)], Plain 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Plain 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Plain 3 [25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Recycled 1 [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Recycled 2 [21 lb. Bond to 24 lb. Bond (76 to 90 g/m2)], Recycled 3[(25 lb. Bond to 28 lb. Bond (91 to 105 g/m2)], Color [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Heavy 1 [29 lb. Bond to 34 lb. Bond (106 to 128 g/m2)], Heavy 2 [35 lb. Bond to 60 lb. Cover (129 to 163 g/m2)], Heavy 3 [61 lb. Cover to 80 lb. Cover [164 to 220 g/m2)], Transparency [32 lb. Bond to 80 lb. Cover (121 to 220 g/m2)], Pre-punched [17 lb. Bond to 20 lb. Bond (64 to 75 g/m2)], Bond [24 lb. Bond (90 g/m2)], Labels [31 lb. Bond to 59 lb. Cover (118 to 160 g/m2)], Envelopes
Warm Up Time From Power On: 34 Seconds
From Sleep Mode: 10 Seconds
Quick Startup Mode: 10 Seconds**
Power Requirements 120 V, 60 Hz, 7.5 A
Power Consumption Maximum: 1.5 kW
Sleep Mode: 1 W
Plug NEMA 5-15
Dimension 24" x 20-1/8" x 24-1/2" (610 mm x 511 mm x 621 mm)
Installation Space 33-1/2" x 24-1/2" ( 852 mm x 621 mm) (When the Multipurpose Tray is extended)
Weight Approx. 99.2 lb. (45 kg)***
Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check
Special Copy Features ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date
Environmental Features ENERGY STAR® Qualified RoHS Compliant Blue AngelEPEAT® Rated WEEE Directive
Advanced Box
Advanced Box Features Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported
Memory Media
Standard Store to USB Memory
Scan Specifications
Network TWAIN Scan Standard: Network WIA Scan
Network Scan Utility Color Network ScanGear 2
Copy/Print Speed (BW/Color)
Letter Up to 26/26 ppm
Legal Up to 21/21 ppm
Copy Specifications
First Copy Time As fast as 8.4 Seconds (BW) and 10.5 Seconds (Color)
Multiple Copies 1 to 999
Copy Exposure Automatic or Manual (9 Levels)
Magnification 25 - 400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 78%
Preset Enlargements 129%, 200%, 400%
Standard Paper Capacity (20 lb. Bond): 550-sheet Paper Cassette 100-sheet Stack Bypass
Optional 1 x 550-sheet Paper Cassette 3 x 550-sheet Paper Cassette
Maximum Paper Capacity 2,300 Sheets
Output Paper Capacity (21 lb. Bond): Standard:250 Sheets
Maximum: 500 Sheets (non-stapled with Staple Finisher-S1 attached)
Output Sizes
Cassette Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 7-1/2" to 8-1/2" x 14") (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)*
Bypass Legal, Letter, Statement, Executive, Custom Size [(3-7/8" x 5-7/8" to 8-1/2" x 14") (98.4 mm x 148 mm to 216 mm x 355.6 mm)], and Envelopes (COM10, Monarch, DL, ISO-C5)
Acceptable Paper Weights
Cassette 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
Bypass 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2)
Duplexing
Paper Size Standard Automatic Trayless Duplexing (Statement to Legal)
Paper Weight Up to 60 lb. Cover (163 g/m2)
Image Reader
Scan Resolution Up to 600 x 600 dpi
Acceptable Originals (Glass): Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2 kg)]
Maximum Original Size Legal (8-1/2" x 14")
Security Features
Standard Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), Send to My Personal Folder (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
Optional HDD Encryption, HDD Erase Scheduler, Encrypted Secured Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification,&diams; imageWARE Secure Audit Manager Express, uniFLOW, AA-Print, Universal Login Manager
Estimated Toner Yield BW: 19,000 Copies/Bottle
Color (C,M,Y): 21,500 Copies/Bottle (Estimated @ 5% Coverage)
Feeders
Description Document Feeder
Acceptable Originals Paper Size: Legal, Letter, Statement Paper Weights: 1-sided scanning (single sheet): 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2) 1-sided scanning (multiple sheets): 13 lb. Bond to 28 lb. Bond (50 to 105 g/m2), 2-sided scanning: 17 lb. Bond to 28 lb. Bond (64 to 105 g/m2)
Scan Method Duplexing Automatic Document Feeder
Scanning Speed Simplex: 26 ipm (300 dpi)/16 ipm (600 dpi)
Duplex: 9 ipm (300 dpi)/7 ipm (600 dpi)
Capacity (20 lb. Bond): 50 Sheets
Paper Supply Options
Description Cassette Feeding Unit-AG1
Paper Capacity 550 Sheets [21 lb. Bond (80 g/m2)]
Paper Size Legal, Letter, Statement, Executive, Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4 mm x 190.5 mm to 216 mm x 355.6 mm)]
Paper Weight 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2)
Power Source From the Main Unit
Power Consumption Approx. 25 W
Dimensions 16-3/4" x 20-1/8" x 20" (425 mm x 511 mm x 508 mm)
Weight Approx. 33.1 lb. (15 kg)
Description Cassette Feeding Unit-AH1
Paper Capacity 550 Sheets x 3 Cassettes [21 lb. Bond (80 g/m2)
Paper Size Legal, Letter, Statement, Executive, and Custom Size [3-7/8" x 7-1/2" to 8-1/2" x 14" (98.4mm x 190.5mm to 216mm x 355.6mm)]
Power Consumption Approx. 35W
Dimensions 16-3/4" x 20-1/8" x 20" (425mm x 511mm x 508mm)
Weight Approx. 41.9 lb (19kg)
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
