Canon Support for imageRUNNER ADVANCE 4535i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Model Name imageRUNNER ADVANCE 4535i
Type Monochrome Laser Multifunctional
Functions Standard: Print, Copy, Scan, Send, Store
Optional: Fax
Operation Panel 10.1" TFT LCD WSVGA Color Touch-panel
Imaging System Canon Dual Custom Processor (Shared)
Image Server Memory 3.0 GB RAM
Hard Disk Drive Standard: 250 GB
Maximum: 1 TB
Mirroring Hard Disk Drive Optional (250 GB, 1 TB)
Method: Raid1
Network Interface Connection Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth
Other Interface Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
Scanning Resolution 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
Printing Resolution 1200 dpi x 1200 dpi
Warm Up Time From Power On: 24 Seconds or Less
From Deep Sleep Mode: 10 Seconds or Less
Quick Startup Mode: 4 Seconds4
Power Requirements 120-127 V AC, 60 Hz, 9.3A
Power Consumption Maximum Approx. 1.5 kWh
Standby: Approx. 38 W
Sleep Mode: Approx. 0.9 W11
Typical Electricity Consumption (TEC) Rating: 1.8 kWh
Plug NEMA 5-15P
Dimension 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5
Installation Space Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm)
Fully Configured [With ADF+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" x 50-3/8" (1,811 mm x 1,280 mm)
Weight Approx. 240.7 lb. (109.2 kg)6
Basic Copy Features Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
Special Copy Features Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original
Advanced Box
Available Disk Space Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
Advanced Box Features Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
Memory Media
Standard USB
Copy/Print Speed (BW/Color)
Letter Up to 35 ppm
Letter R Up to 32 ppm
Legal Up to 25 ppm
Ledger Up to 22 ppm
Copy Specifications
First Copy Time (Letter): As fast as 3.8 seconds
Multiple Copies Up to 999 copies
Copy Exposure Automatic or Manual (9 Levels)
Magnification 25%-400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 73%, 78%
Preset Enlargements 121%, 129%, 200%, 400%
Acceptable Originals Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
Standard Paper Capacity (LTR, 20 lb. Bond): 1,180 Sheets
Optional (LTR, 20 lb. Bond): Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1)
Manual Bypass 80-sheet Stack Bypass
Maximum Paper Capacity (LTR, 20 lb. Bond): 6,330 Sheets
Output Paper Capacity (LTR, 20 lb. Bond): Standard: 250 Sheets
Maximum: 3,350 Sheets (with External Finishers)
Output Sizes
Cassette Paper Cassette (1): Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Paper Cassette (2): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
Bypass 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
Acceptable Paper Weights
Cassette 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
Bypass 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing
Duplexing 16 lb. Bond to 28 lb. Cover (60 to 105 g/m2)
Toner GPR-57 Toner BK
Estimated Toner Yield (Estimated @ 6% Coverage): 42,100 Copies
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
