Canon Support for imageRUNNER ADVANCE 4525i | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER ADVANCE 4500 Series Spec Sheet
imageRUNNER ADVANCE 4525i | |
MAIN UNIT | |
TYPE | Monochrome Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Touch-panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB Maximum: 1 TB |
MIRRORING HARD DISK DRIVE | Optional (250 GB, 1 TB) Method: Raid1 |
PRINT RESOLUTION | 1200 dpi x 1200 dpi |
INTERFACE CONNECTION | Network Standard: 1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n) Optional: NFC, Bluetooth Others Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
PAPER CAPACITY (LTR, 20LB BOND) | Standard: 1,180 SheetsMaximum: 6,330 Sheets |
PAPER SOURCES (LTR, 20LB BOND) | Standard: Two 550-sheet Paper Cassettes,80-sheet Stack Bypass Optional: Two 550-sheet Paper Cassettes(Cassette Feeding Unit-AN1), 2,450-sheetPaper Deck (High Capacity CassetteFeeding Unit-B1), 2,700-sheet Paper Deck(Paper Deck Unit-F1) |
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) | Standard: 250 Sheets Maximum: 3,350 Sheets (with External Finishers) |
FINISHING CAPABILITIES | Standard: Collate, Group With InnerFinisher:Collate, Group, Offset, Staple,Hole Punch,1 Staple-Free Staple,Staple On Demand With ExternalFinisher:Collate, Group, Offset, Staple, Booklet,2Staple-Free Staple, Staple On Demand,Hole Punch3 |
SUPPORTED MEDIA TYPES | Paper Cassettes:Thin, Plain, Recycled, Color, Heavy,Pre-punched Stack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency,Label, Envelope |
SUPPORTED MEDIA SIZES | Paper Cassette (1):Legal, Letter, Letter-R, Executive, Statement-R, Custom Size(5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") PaperCassette (2):11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size(5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")Stack Bypass:11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17") |
SUPPORTED MEDIA WEIGHTS | Paper Drawers:Paper Cassettes:16 lb. Bond to 34 lb. Bond (60 to 128 g/m2) Stack Bypass:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Duplexing:16 lb. Bond to 28 lb. Cover (60 to 105 g/m2) |
WARM-UP TIME | From Power On:24 Seconds or Less From Deep Sleep Mode:10 Seconds or Less Quick Startup Mode:4 Seconds4 |
DIMENSIONS (W X D X H) | 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5 |
INSTALLATION SPACE (WXD) | Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm) Fully Configured [With ADF+Paper Deck Unit-F1+Booklet Finisher-Y1 (Cassette Drawers Open)]:71-3/8" x 50-3/8" (1,811 mm x 1,280 mm) |
WEIGHT | Approx. 240.7 lb. (109.2 kg)6 |
PRINT SPECIFICATIONS | |
PRINT SPEED | Up to 25 ppm (Letter); Up to 17 ppm (Letter-R); Up to 13 ppm (Legal); Up to15 ppm (11" x 17") |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI,and Web Access (Opt.)7 |
SUPPORTED FILE TYPES FOR DIRECT PRINT | PDF, TIFF, JPEG, EPS, XPS |
PRINTING FROM MOBILE AND CLOUD | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9 PS fonts:136 Roman |
OPERATING SYSTEM10 | UFRII:Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later) PCL:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10 PS:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later) PPD:MAC OS 9.1 or later, MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10 |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
COPY SPEED | Up to 25 ppm (Letter); Up to 17 ppm (Letter-R); Up to 13 ppm (Legal); Up to15 ppm (11" x 17") |
FIRST-COPY-OUT-TIME | As fast as 5.2 seconds |
COPY RESOLUTION | Reading:Up to 600 dpi x 600 dpi Printing:1200 dpi x 1200 dpi |
MULTIPLE COPIES | Up to 999 copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter,Print & Check, Negative/Positive, Repeat Images,Merge Job Blocks, Job Done Notice, Mirror Image,Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original |
SCAN SPECIFICATIONS | |
TYPE | Optional Single Pass DuplexingAutomatic Document Feeder orDuplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | Single Pass DADF-A1: 150 Sheets (20 lb. Bond)DADF-AV1: 100 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT | Single Pass DADF-A1 BW Original:13 lb. Bond to 58 lb. Cover(50 to 157 g/m2) CL Original:17 lb. Bond to 58 lb. Cover(64 to 157 g/m2) DADF-AV1 BW Original:13 lb. Bond to 34 lb. Bond(50 to 128 g/m2) CL Original:17 lb. Bond to 34 lb. Bond(64 to 128 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA Supported OS:Windows Vista/7/8/8.1/10Windows Server 2008/Server 2008 R2/Server 2012/Server 2012 R2 |
SCAN RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements. |
SCAN SPEED (LETTER) | Single Pass DADF-A1 Single-sided Scanning (BW):80 ipm (300 dpi)/80 ipm (600 dpi) Single-sided Scanning (Color):80 ipm (300 dpi)/60 ipm (600 dpi) Double-sided Scanning (BW):160 ipm (300 dpi)/150 ipm (600 dpi) Double-sided Scanning (Color):160 ipm (300 dpi)/80 ipm (600 dpi) DADF-AV1 Single-sided Scanning (BW):70 ipm (300 dpi)/51 ipm (600 dpi) Single-sided Scanning (Color):70 ipm (300 dpi)/51 ipm (600 dpi) Double-sided Scanning (BW):35 ipm (300 dpi)/25.5 ipm (600 dpi) Double-sided Scanning (Color):35 ipm (300 dpi)/25.5 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
ADDRESS BOOK | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White |
SEND RESOLUTION | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi |
COMMUICATION PROTOCOL | File:FTP, SMB v3.0, WebDAV E-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full) |
FILE FORMAT | Standard:TIFF, JPEG, PDF(Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word) Optional:PDF (Trace & Smooth, Encrypted),PDF/XPS (Digital Signature) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 4 |
MODEM SPEED | Super G3:33.6 Kbps G3:14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 dials |
SEQUENTIAL BROADCAST | Max. 256 addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed |
STORE SPECIFICATIONS | |
MAIL BOX (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAVSupportedClient PC:Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.) SMB:64 WebDAV:3 (Active Sessions) |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
ADVANCED BOX FEATURES | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard:Universal Login Manager, User Authentication, Department ID Authentication, AccessManagement System, Deviceand Function Level Log-in Optional:uniFLOW |
DATA | Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW) |
NETWORK | Standard:IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard:Secure Print, Forced Hold Printing,Adobe LiveCycle® Rights Management ES2.5 Integration Optional:Encrypted PDF, Encrypted Secure Print, User and Device signatures, Secure Watermarks, Document Scan Locking |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature:50 to 86ºF Humidity:20 to 80% RH (no condensation) |
POWER REQUIREMENTS | 120-127 V AC, 60 Hz, 7A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | MaximumApprox. 1.5 kWh Standby:Approx. 38 W Sleep Mode:Approx. 0.9 W11 Typical Electricity Consumption (TEC) Rating:1.0 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Gold12 RoHS Compliant |
CONSUMABLES | |
TONER | GPR-57 Toner |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | Black: 42, 100 Copies |
FOOTNOTES | |
1 Requires the optional Inner 2/3 Hole Puncher-C1. 2 Booklet Finisher-Y1 only. 3 Requires the optional 2/3 Hole Puncher Unit-A1. 4 Time from device power-on to when copy jobs can be programmed. 5 Includes Main Unit, Single Pass DADF-A1, and Cassette Feeding Unit-AN1. 6 Includes Main Unit, Single Pass DADF-A1, Cassette Feeding Unit-AN1, and consumables. 7 PDF print from Web sites is supported. 8 Requires the optional PCL International Font Set-A1. 9 Requires the optional Barcode Printer Kit-D1. 10 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 11 0.9 W Sleep mode is not available in all circumstances due to certain settings. 12 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. |
