Canon Support for imageRUNNER ADVANCE 4225 | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
imageRUNNER ADVANCE 4200 Srs Setup Guide
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE 4225 |
Type | Digital Multifunction Imaging System |
Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines)Processor Canon Dual Custom Processor (Shared) |
Operation Panel | 8.4" SVGA Full-Color TFT Screen |
Image Server Memory | Standard: 1.25GB RAM Maximum: 1.75GB RAM |
Hard Disk Drive | Standard: 160GB Maximum: 1TB |
Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
Network Interface Connection | Standard: 10/100/1000Base-TX Optional: Wireless LAN |
Other Interface | Standard: USB 2.0 (Host) x 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface |
Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes |
Max Pages Stored | 6,000 Maximum Pages Stored |
Special Media Support | Tracing, Labels, Transparency, and Envelopes |
Warm Up Time | From Power On: 30 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 7 Seconds*** |
Power Requirements | 120V AC, 60Hz, 10.4A |
Power Consumption | Maximum: 1,500W Sleep Mode: 0.9W |
Plug | NEMA 5-15P |
Dimension | 30-3/8" x 22-1/4" x 27-5/8" (771mm x 565mm x 700mm) |
Installation Space | (when the Multi-Purpose Tray is extended): 34-1/2" x 27-5/8 (876mm x 700mm) |
Weight | Approx. 154 lb. (70kg) |
Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-sided, Density/Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
Special Copy Features | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, ID Card Copy, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Job Block Combination, Store in User Inbox |
Environmental Features | ENERGY STAR® Qualified Rated EPEAT® Silver RoHS Compliant Ecomark Blue Angel WEEE Directive |
Advanced Box
Available Disk Space | Approx. 15GB (Standard HDD) Approx. 629GB (1TB HDD) |
Common Protocol | SMB or WebDAV |
Supported Client PC | Windows (Windows 2000/XP/Windows Vista/7) |
Max. Number of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
Standard | USB Memory |
Optional | SD, SDHC, CompactFlash®, Memory Stick, Microdrive |
Scan Specifications
Network TWAIN Scan | Standard |
Network Scan Utility | Color Network ScanGear |
Copy/Print Speed (BW/Color)
Letter | Up to 25 ppm (BW) |
Legal | Up to 13 ppm (BW) |
Ledger | Up to 15 ppm (BW) |
Copy Specifications
First Copy Time | (Letter): As fast as 5.2 Seconds |
Multiple Copies | 1 to 999 |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | From Platen Glass: 25% - 400% (1% increments) From ADF: 25% - 200% (1% increments) |
Preset Reductions | 25%, 50%, 64%, 73%, 78% |
Preset Enlargements | 121%, 129%, 200%, 400% |
Standard Paper Capacity | Dual 550-sheet Paper Cassettes |
Optional | Dual 550 Sheet Paper Cassettes, 2,700-sheet Paper Deck |
Manual Bypass | 80-sheet Stack Bypass |
Maximum Paper Capacity | 4,980 Sheets |
Output Paper Capacity | (20 lb. Bond): Standard: 250 Sheets (Inner Tray) Maximum: 3,100 Sheets (w/Staple Finisher or Booklet Finisher) |
Output Sizes
Cassette | Cassette 1: Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") Cassettes 2/3/4: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 17") |
Bypass | 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17") |
Other Option | Envelope Feeder Attachment** (COM10 No.10, Monarch, DL, ISO-C5) |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 34 lb. Bond (60 to 128g/m2) |
Bypass | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
Duplexing
Paper Size | Standard Automatic Trayless Duplexing (Executive to 11" x 17") |
Paper Weight | 14 lb. Bond to 28 lb. Bond (52 to 105g/m2) |
Image Reader
Scan Resolution | Up to 600 x 600 dpi† |
Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2kg)] |
Maximum Original Size | Up to 11" x 17" |
Security Features
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPsec, Adobe LiveCycle Rights Management ES2.5 Integration |
Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification⟩ |
Estimated Toner Yield | 30,200 Copies/Bottle (Estimated @ 6% Coverage) |
Feeders
Description | Duplexing Automatic Document Feeder (Optional) |
Acceptable Originals | 11" x 17", Legal, Letter, Letter-R, Statement |
B/W Originals | BW: 11 lb. Bond to 34 lb. Bond (42 to 128g/m2) |
Color Originals | Solid Black Text/Color: 17 lb. Bond to 34 lb. Bond (64 to 128g/m2) |
Scanning Speed | (BW/Color; Letter): Simplex: 51/51 ipm (300 dpi) 51/30 ipm (600 dpi)† |
Capacity | (20 lb. Bond): 100 Sheets |
Paper Supply Options
Description | Cassette Feeding Unit-AF1 |
Paper Capacity | 550 Sheets x 2 Cassettes [20 lb. Bond (80g/m2)] |
Paper Size | 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2" x 7-1/8" to 11-3/4" x 17" (140mm x 182mm to 297mm x 431mm)] |
Paper Weight | 16 lb. Bond to 34 lb. Bond (60 to 128g/m2) |
Power Source | From the Main Unit |
Power Consumption | Approx. 30W |
Dimensions | 9-3/4" x 24-1/8" x 25-5/8" (248mm x 565mm x 650mm) |
Weight | Approx. 61 lb. (27.5kg) |
Description | Paper Deck Unit-B2 |
Number Of Cassettes | 1 |
Paper Capacity | 2,700 Sheets [20 lb. Bond (80g/m2)] |
Paper Size | Letter |
Power Source | From Main Unit |
Power Consumption | Approx. 35W |
Dimensions | 18-5/8" x 14-5/8" x 23-3/4" (473mm x 372mm x 603mm) |
Weight | Approx. 81.6 lb. (37kg) |
Description | Envelope Feeder Attachment-D1** |
Paper Capacity | 50 Sheets (or 30mm in height) |
Paper Size | COM10 No.10, Monarch, DL, ISO-C5 |
Dimensions | 3-1/4" x 17-1/4" x 12-1/8" (81mm x 439mm x 307mm) |
Weight | Approx. 2.6 lb. (1.2kg) |
