Canon Support for imageRUNNER 1643iF | Canon U.S.A., Inc.
imageRUNNER 1643iF
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER 1643 Series Brochure
imageRUNNER 1643iF | |
MAIN UNIT | |
TYPE | Monochrome Laser Multifunctional |
CORE FUNCTIONS | Print, Copy, Scan, Send, Fax |
PROCESSOR | Canon Dual Custom Processor2 (Shared) |
OPERATION PANEL | 5" TFT LCD WVGA Color Touch Panel |
MEMORY | 1.0 GB RAM |
INTERFACE CONNECTION | Network (Standard): 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n), NFC,1 Wi-Fi Direct Connection Others (Standard): USB 2.0 (Host) x2, USB 2.0 (Device) x1 |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3) Maximum: 2,300 Sheets |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Maximum: 150 Sheets |
SUPPORTED MEDIA SIZES | Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
SUPPORTED MEDIA WEIGHTS | Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) |
COPY SPEED/PRINT SPEED | Up to 45 ppm (Letter); Up to 36 ppm (Legal) |
WARM-UP TIME | From Power On: 14 Seconds or Less2 From Sleep Mode: 4 Seconds or Less |
DIMENSIONS (W x D x H) | 19-7/16” x 18-5/16” x 17-3/16” (494 mm x 465 mm x 452 mm) |
INSTALLATION SPACE (W x D x H) | 27-7/8” x 43-1/2” (708 mm x 1105 mm) |
WEIGHT3 | Approx. 41.9 lb. (19 kg) |
PRINT SPECIFICATIONS | |
FIRST-PRINT-OUT TIME (LTR) | Approx. 5.7 Seconds |
PRINT RESOLUTION (dpi) | 600 × 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit |
DIRECT PRINT | Supported File Types: TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR |
OPERATING SYSTEM | Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 , 10/14) Linux (Web Distribution) |
PRINT FEATURES | Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIME | As fast as 6.0 Seconds (via Platen) |
COPY RESOLUTION (dpi) | Reading/ Printing: Up to 600 x 600 |
COPY SPECIFICATIONS | Automatic or Manual (9 Levels) |
MULTIPLE COPIES | Up to 999 |
MAGNIFICATION | 25% - 400% (1% Increments) from Platen Glass |
PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
PRESET ENLARGEMENTS | 129%, 200%, 400% |
BASIC COPY FEATURES | Preset R/E Ratios by Area, Paper Setting, Favorite Setting, Two-Sided, Density Adjustment, Original Type Selection |
SPECIAL COPY FEATURES | Two-sided Original, Sort, Job Build, N on 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Copy ID Card |
SCAN SPECIFICATIONS | |
TYPE | Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | LTR: 50 Sheets (20 lb. Bond), LGL: 30 Sheets (20 lb. Bond) |
MAXIMUM ORIGINAL SIZE | Up to 8-1/2" x 14" |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 4-1/8" x 5" to 8-1/2" x 14" |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2) Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book, 3-Dimensional Objects |
NETWORK TWAIN SCAN | Standard |
NETWORK SCAN UTILITY | ScanGear MF |
SCAN RESOLUTION | Up to 600 x 600 |
SCAN SPEED (LETTER) | 300 dpi Simplex: Up to 38ipm (BW)/ 13ipm (Color) / Duplex: Up to 70ipm (BW)/ 26 (Color) 600 dpi Simplex: Up to 21 ipm (BW) / Duplex: Up to 35 ipm (BW) |
SEND SPECIFICATIONS | |
DESTINATION | E-mail/Internet FAX (SMTP), SMB, FTP |
COLOR MODE | Color, BW |
ADDRESS BOOK | LDAP (50)/Local (300)/Speed Dial (281) |
SEND RESOLUTION | 600 dpi, 300 dpi (CL/BW) |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB (TCP/IP) Email: SMTP, POP3 |
FILE FORMAT | Standard: TIFF, JPEG, PDF(Compact, Searchable, Encrypted, Digital Signature) |
UNIVERSAL SEND FEATURES | Original Type Selection, Two-sided Original, Density Adjustment, Sharpness, File Name, Subject/Message, E-mail Priority, TX Report, Original Content Orientation |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | One |
MODEM SPEED | Super G3: 33.6 Kbps G3: 14.4 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Letter, Legal, Statement, Executive |
FAX FEATURES | Two-sided Original, Density (for Scanning), Sharpness, TX Report, RX Mode, Resolutions, Favorite Settings |
STORE SPECIFICATIONS | |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Department ID, Embedded Universal Login Manager, uniFLOW Online Express4 Optional: uniFLOW and uniFLOW Online |
NETWORK | Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard: Secure Print, Encrypted PDF, Device Signature |
ENVIRONMENTAL SPECIFICATIONS | |
POWER REQUIREMENTS | 120-127 V, 60 Hz, 7.1 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1430W Sleep Mode: 0.9 W5 Typical Electricity Consumption (TEC) Rating:6 0.40 kWh |
STANDARDS | ENERGY STAR® Certified Rated EPEAT® Silver1 |
CONSUMABLES | |
TONER | T06 Black (All-In-One Toner Cartridge) |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | 20,500 images (Estimated Yield @ ISO 19752 Coverage) |
FOOTNOTES | |
