Canon Support for imageRUNNER 1643i | Canon U.S.A., Inc.
imageRUNNER 1643i
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Model Name imageRUNNER 1643i
Type Monochrome A4 Laser Multifunctional
Functions Print, Copy, Scan, Send
Operation Panel 5" TFT LCD WVGA Color Touch Panel
Imaging System Canon Dual Custom Processor (Shared)
Image Server Memory 1.0 GB RAM
Network Interface Connection 1000Base-T/100Base-TX/10-Base-T, Wireless LAN (IEEE 802.11 b/g/n), NFC (only 1643iF), Wi-Fi Direct Connection
Other Interface USB 2.0 (Host) x2, USB 2.0 (Device) x1
Max Mailboxes Supported LDAP (50)/Local (300)/Speed Dial (281)
Max Copy Reservation Up to 600 x 600
Scanning Resolution Up to 600 x 600
Printing Resolution 600 × 600
Warm Up Time From Power On: 14 seconds or Less2
From Sleep Mode: 4 Seconds or Less
Power Requirements 120-127 V, 60 Hz, 7.1 A
Power Consumption Maximum: 1,500 W
Sleep Mode: 0.9W or Less5
Plug NEMA 5-15P
Dimension 18-7/8" x 23-1/2" x 17-3/4" (480 mm x 595 mm x 452 mm)
Installation Space 27-3/8" x 43-1/2" (694 mm x 1105 mm)
Weight Approx. 41.9 lb. (19 kg) 3
Basic Copy Features Preset R/E Ratios by Area, Paper Setting, Favorite Setting, Two-Sided, Density Adjustment, Original Type Selection
Special Copy Features Two-sided Original, Sort, Job Build, N on 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Copy ID Card
Environmental Features ENERGY STAR&reg; Certified
Rated EPEAT&reg; Gold1
Advanced Box
Common Protocol File: FTP (TCP/IP), SMB (TCP/IP)
Email: SMTP, POP3
Max. Number of Concurrent Connections One
Memory Media
Standard USB
Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility ScanGear MF
Copy/Print Speed (BW/Color)
Letter Up to 45 ppm
Legal Up to 36 ppm
Copy Specifications
First Copy Time As fast as 6.0 Seconds (via Platen)
Multiple Copies Up to 999
Magnification 25% - 400% (1% Increments) from Platen Glass
Preset Reductions 25%, 50%, 64%, 78%
Preset Enlargements 129%, 200%, 400%
Acceptable Originals Sheet, Book, 3-Dimensional Objects
Maximum Original Size Up to 8-1/2" x 1
Standard Paper Capacity 550-sheet Paper Cassette
Optional 550-sheet PAPER FEEDER PF-C1 (up to 3)
Manual Bypass 100-sheet Stack Bypass
Maximum Paper Capacity 2,300 Sheets
Output Paper Capacity Maximum: 250 Sheets
Output Sizes
Cassette Letter, Legal, Statement, Executive
Bypass Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch)
Acceptable Paper Weights
Cassette 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Bypass 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2)
Duplexing
Duplexing Duplexing Automatic Document Feeder
Paper Size 4-1/8" x 5" to 8-1/2" x 14"
Paper Weight Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
Security Features
Standard Authentication: Department ID Authentication and embedded Universal Login Manager with uinFLOW Online/Online Express,4 IP/ Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, Secure Print, Encrypted PDF, Device Signature
Optional Authentication: uniFLOW
Estimated Toner Yield (Estimated Yield @ 5% Coverage) 20,500 Images
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
