Canon Support for imageRUNNER 1435i | Canon U.S.A., Inc.
imageRUNNER 1435i
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
imageRUNNER 1400 Series Spec Sheet
imageRUNNER 1435i | |
MAIN UNIT | |
SYSTEM TYPE | Digital Multifunction Imaging System |
FUNCTIONS | Copy, Print, Scan, Send |
OPERATION PANEL | 5-line LCD |
MEMORY | RAM 512 MB; Standard USB Port |
NETWORK INTERFACE CONNECTION | Standard: 1000Base-T, 100Base-TX, 10Base-T Other: USB2.0 x1 (Host), USB1.1 x1(Host), USB (Device) |
COPY SPEED | Letter: Up to 37 ppm Legal: Up to 25 ppm |
PRINT SPEED | Letter: Up to 37 ppm Legal: Up to 25 ppm |
FIRST-COPY-OUT TIME (LETTER) | As fast as 6.9 Seconds |
FIRST-PRINT-OUT TIME (LETTER) | As fast as 5.0 Seconds |
PAPER SOURCES (20 lb. Bond) | Standard: 500-sheet Cassette 100-sheet Bypass Optional: 500-sheet Cassette Maximum: 1,100 Sheets |
OUTPUT CAPACITY (20 lb. Bond) | Maximum: 100 Sheets |
OUTPUT PAPER SIZES | Cassette: Letter, Legal Bypass: Letter, Legal, Statement, Executive, Custom Size (3” x 5” to 8-1/2” x 14”), Envelope (C5/DL/ COM-10/Monarch) |
ACCEPTABLE PAPER WEIGHTS | Cassette: 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2) Bypass: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2 |
WARM-UP TIME | From Power On: 20 Seconds or Less From Sleep: 7.8 Seconds or Less |
POWER REQUIREMENTS / PLUG | 120-127 V AC, 60 Hz, 7.8 A/NEMA 5-15P |
POWER CONSUMPTION | Maximum: 1,500 W Sleep Mode: 2.0 W or Less |
DIMENSIONS (W X D X H) | 18-3/4” x 21-1/2” x 18” (475.3 mm x 545 mm x 457 mm) |
INSTALLATION SPACE (WXD) | 30-3/8” x 18” (772.1 mm x 457 mm) (when the Multi-purpose Tray is extended) |
WEIGHT | Approx. 52.3 lb. (23.74 kg) |
IMAGE READER UNIT | |
SCAN RESOLUTION | Up to 600 x 600 dpi |
ACCEPTABLE ORIGINALS (GLASS) | Sheet, Book, 3-Dimensional objects up to 4.4 lb. (2 kg) |
MAXIMUM ORIGINAL SIZE | Up to 8-1/2” x 14” |
DOCUMENT FEEDER | |
SCAN METHOD | Duplexing Automatic Document Feeder |
ACCEPTABLE ORIGINALS | Paper Sizes: 5-1/2” x 5” to 8-1/2” x 14” Paper Weights: Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2) Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2) |
SCAN SPEED (BW / COLOR; LETTER) | Simplex: Up to 29 ipm (BW)/10 ipm (Color) Duplex: Up to 10 ipm (BW)/6 ipm (Color) |
PAPER CAPACITY (20 lb. Bond) | : Up to 50 Sheets (20 lb. Bond) |
COPY SPECIFICATIONS | |
MULTIPLE COPIES | 1 to 999 |
COPY EXPOSURE | Automatic or Manual (17 Levels) |
MAGNIFICATION | 25% - 400% (1% Increments) from Platen Glass |
PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
PRESET ENLARGEMENTS | 129%, 200%, 400% |
BASIC COPY FEATURES | Preset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check |
SPECIAL COPY FEATURES | ID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original |
PRINT SPECIFICATIONS | |
PROCESSOR | Canon Dual Custom Processor (Shared) |
ENGINE RESOLUTION | 600 x 600 dpi; 1200 x 600 dpi (Enhanced) |
PDL SUPPORT | Standard: UFR II LT Standard (1435iF/1435P): PCL 5e/6, and Adobe PS 3 Optional: Barcode Printing Kit |
PRINT DRIVERS SUPPORTED OS | UFR II LT, PCL 5e/6, Adobe PS 3, Windows® (XP/Windows Vista®/7/8/8.1), Windows Server (2003/2003R2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2),Microsoft App-V, Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 or later) (UFR II LT, PS 3) |
DIRECT PRINT SUPPORT | Standard: TIFF, JPEG |
PRINT FEATURES | Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/ Back Covers, Objective, Toner Reduction, Poster Printing |
SCAN SPECIFICATIONS | |
NETWORK TWAIN SCAN | Standard |
NETWORK SCAN UTILITY | ScanGear MF |
UNIVERSAL SEND SPECIFICATIONS | |
SENDING METHOD | E-mail, USB, File Server (FTP, SMB) |
COLOR MODE | Color: 300 dpi, 200 dpi, 150 dpi BW: 300 dpi, 150dpi |
SCAN RESOLUTION | 600 x 600 dpi, 400 |
ADDRESS BOOK CAPACITY | Max. 300 Destinations (Incl. 19 One-Touch Buttons) |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB (TCP/IP) E-mail: SMTP, POP3 |
FILE FORMAT | Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Compact/OCR), PDF (OCR) Optional: Encrypted PDF, Digital Signature PDF |
UNIVERSAL SEND FEATURES | Two Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to, E-mail Priority, Senders Name |
STORE SPECIFICATIONS | |
STANDARD | USB Memory |
SECURITY SPECIFICATIONS | |
STANDARD | Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (ASend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Forwarding, Fax Destination Confirmation, USB Block, TLS Support for E-mail , Fax TX Archive |
OPTIONAL | Encrypted PDF, Device Signature PDF, uniFLOW |
ENVIRONMENTAL INFORMATION | |
ENERGY STAR® Qualified Rated EPEAT® Silver EU RoHS Compliant Blue Angel WEEE Directive | |
CONSUMABLES | |
TONER | GPR-54 Toner |
TONER YIELD (ESTIMATED @ 6% COVERAGE) | Black: 17, 600 Copies/Case |
FOOTNOTES | |
* Duplexing Automat |
