Canon Support for imagePROGRAF iPF6100 | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.04.08
File Size 32.73 KB
Date 12.16.09
File Size 234.48 MB
Date 01.04.08
File Size 32.73 KB
Date 06.01.07
File Size 394.82 MB
Date 01.04.08
File Size 14.23 MB
Date 07.02.12
File Size 35.98 MB
Date 12.16.09
File Size 280.93 MB
Date 11.14.07
File Size 9.73 MB
Date 09.04.19
File Size 3.53 MB
Date 08.29.24
File Size 5.30 MB
Printer Type 12-Color 24-inch Printer
Number of Nozzles Total: 30,720
All colors: 2,560 nozzles each
Nozzle Pitch 1,200 dpi
Nozzle Recovery System Non-firing nozzle detection and compensation
Print Resolution (Up to) 2,400 x 1,200 dpi (Max)
OS Compatibility Windows&#174;(2000/XP/Vista 32/64bit)
MAC(OS9,OS10)1
Standard Interfaces USB 2.0 High-Speed
10/100 Base-T/TX
Optional: IEEE 1394 (Firewire&#174)
Ink Droplet Size 4 picoliter
Ink Capacity 130ml per color2
Ink Droplet Size LUCIA ink (Pigment-based)
Color Set Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Red, Green. Blue, Gray, Photo Gray
Buffer Ram 384 MB
Hard Drive N/A
Media Width Cut Sheet and Roll: 8" - 24"
Media Thickness Top Loading Manual Feed: 0.08 - 0.8mm (3.2 - 31.4mil)
Front Loading Manual Feed: 0.5 - 1.5mm (19.6 - 59.0mil)
Roll: 0.08 - 0.8mm (3.2 - 31.4mil)
Maximum Roll Print Length 62 Feet (Top)
36 Feet (Front)
Maximum Media Roll Diameter 5.9" (150mm)
Borderless Printing Width 10" (254 mm), B4 (257 mm), A3+ (329 mm), 14" (356 mm), 16" (407 mm), A2 (420 mm), A2+/17" (432 mm), B2 (515 mm), A1 (594 mm), 24" (610 mm)
Paper Feed Method Roll Feed: One Roll, front output
Top Loading Manual Feed: One sheet, front output
Front Loading Manual Feed: One sheet, front output
Languages GARO (Canon Proprietary)
Noise Level Approx Operation: 49 dB or less
Standby: 6W or less
Physical Dimensions 39.1" (H) x 46.3" (W) x 35.2" (D)
Weight Approximately 150 lbs with stand
Power Source AC-100-120V (50-60Hz)
Power Consumption Maximum: 100W or less
Standby 6W or less
Power Off: Less than 1W (Compliant with Executive Order)
Operating Environment Temperature: 59&#176;-86&#176; F (15&#176;-30&#176; C)
Relative Humidity: 10-80% (No Condensation)
User-replaceable items Print Head (PF-03), Maintenance Cartridge (MC-16)
Software Included Canon Printer Driver, Print Plug-in for Adobe Photoshop, Print Plug-in for Digital Photo Professional, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, imageRUNNER Linking Function)
SUPPLIES & ACCESSORIES
