Canon Support for imageFORMULA ScanFront 400 CAC/PIV Office Document Scanner | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 03.15.17
File Size 3.15 MB
Date 03.15.17
File Size 3.04 MB
Model Name imageFORMULA ScanFront 400 CAC/PIV
Type Networked Document Scanner
Document Feeding Automatic or Manual
Document Size Width: 1.95" - 8.5"
Length: 2.12" - 14.0"*
Long Document Mode Up to 120"
Folio Mode: Up to 11" x 17"
Document Weight 14 - 57 lb. Bond Plain Paper
Feeder Capacity Up to 60 Sheets
Grayscale 8-bit
Color 24-bit
Light Source RGB LED
Scanning Element 3-Line Contact Image Sensor (CMOS)
Scanning Modes Color, Grayscale, Black & White
Optical Resolution Up to 600 dpi
Output Resolution 100/150/200/300/400/600 dpi
Scanning Speeds (Simplex / Duplex):** Black and White: Up to 45 ppm / Up to 90 ipm
Grayscale: Up to 45 ppm / Up to 90 ipm
Color: Up to 45 ppm / Up to 90 ipm
Interface USB 2.0 (x3), 10Base-T/100Base-T/1000Base-T
Operation Panel: 10.1" WSVGA TFT Liquid Crystal Display with Touch-Panel
Dimensions (H x W x D) 9.06" x 12.0" x 11.1"
Weight 9.92 lb.
Power Consumption 36W or less
Suggested Daily Volume 6,000 scans***
Bundled Software ScanFront Administration Tool
Supported Operating Systems Windows 64-bit, 32-bit
Options Exchange Roller Kit, eCarePAK Extended Service, Passport Carrier Sheet, A4 Carrier Sheet
Network Functions: Scan-To-E-mail (SMTP Microsoft Exchange, Lotus Notes), Scan-To-Fax (SMTP-via Internet fax service or via direct transmissions, Microsoft Exchange, Lotus Notes), Scan-To- Folder, Scan-To-Print, Scan-To-FTP, Scan-To-USB Drive
Other Features Automatic Page Size Detection, Background Smoothing, Background Removal, Bleed-through Reduction, Color Dropout/Enhancement, Deskew, Double-Feed Detection, Folio, Long Document Mode, Optical Character Recognition (OCR), Shadow Removal, Skip Blank Page, Text Enhancement, Text Orientation Recognition
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
