Canon Support for imageFORMULA DR-9080C Color Production Scanner | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
File Name 9080UM.pdf
Date 03.14.07
File Size 1.86 MB
File Name 9080QRG.pdf
Date 08.07.08
File Size 733.0 KB
Model Name DR-9080C Color Document Scanner
Type Color Production Document Scanner
Document Feeding Automatic or Manual
Document Size Width 2.2" - 12"
Document Size Length 2.8" - 17" (up to 39.4" long doc. mode)
Thickness Automatic Feeding 0.06 - 0.15mm
Thickness Manual Feeding 0.05 - 0.3mm
Feeder Capacity 500 sheets (LTR)
Grayscale 8-bit
Color 24-bit
Scanning Element Contact Image Sensor (CMOS)
Light Source RGB LED x 4
Operating Modes Simplex, Duplex, Color, Grayscale, Black & White, Advanced Text Enhancement, Smoothing, Multistream&#153;
Drop Out Color RGB - User selectable (front/back/both)
Optical Resolution 600 dpi
Output Resolution 100, 150, 200, 300, 400, 600 dpi
Scanning Speeds
Black And White 90 ppm, 180 ipm
Grayscale 90 ppm, 180 ipm
Color 24 Bit 55 ppm, 95 ipm (with JPEG compression)
Interface 1 USB 2.0 and 2 SCSI-III
Scanner Drivers For Windows&reg; 98SE/2000/Me/XP, Windows NT&reg;: isis/TWAIN Bundled Software: CapturePerfect
Dimensions 12.2" x 18.1" x 20.7"
Weight Approx. 55 lbs.
Power Consumption Max 28W
Options Imprinter, Endorser, Mechanical Counter, Barcode Module, Exchange Roller kit
Title To Users of the imageFORMULA R-Series, P-Series and DR-Series Scanners
Advisory Type
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
