Canon Support for imageCLASS MF4450 | Canon U.S.A., Inc.
imageCLASS MF4450
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.15.11
File Size 8.03 MB
Date 04.15.11
File Size 4.77 MB
Date 04.15.11
File Size 7.04 MB
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 10.09.20
File Size 819.56 KB
Date 09.17.24
File Size 2.27 MB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.13.21
File Size 652.14 KB
Date 12.22.17
File Size 647.92 KB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
imageCLASS MF4450
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF4450
Printer
Printing Method Monochrome Laser
Print Speed (up to) Black:Up to 24 ppm (letter)
Print Resolution (Up to) Black:Up to 600 x 600 dpi
1200 x 600 dpi quality
Toner Compatibility (for Laser MFP) Canon Cartridge 128
CRG Yield* 2,100
*Yield based on ISO/IEC Standard
Paper Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Automatic Sheet Feeder 35-sheet Simplex3
Paper Weights 16 to 43 lb. bond (cassette),
16 to 43 lb. bond (multipurpose tray)
Output Tray Capacity Approx. 100 sheets (facedown) 2
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Up to 24 cpm (letter)
Zoom 25-400% in 1% increments
Halftones 256 levels
First Copy Time Approximately 9 seconds
Reduction / Enlargement 25%, 50%, 64%, 78%/ 129%, 200%, 400%
Scanner
Scanner Type Color Contact Image Sensor (CIS)
Max. Resolutions Optical:Up to 600 x 600 dpi
Interpolated:9600 x 9600
Scanner Features Rotate, Push Scan (Scan to PC), Pull Scan
Color Depth 24-bit
File Format Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP2
Fax
Modem Speed Up to 33.6 Kbps (Super G3)
Fax Resolution Up to 203 x 391 dpi (super fine)
Memory Capacity Up to 256 sheets1
Speed Dialing 4 one-touch speed dials;
100 coded dials
Fax Features Distinctive Ring Pattern Detection, Remote RX, Dual Access Fax, Auto Redial, Auto Fax Reduction, Fax Activity Reports, Manual Fax Forwarding
General
Other Features Compatibility
TWAIN, WIA
OS Compatibility Windows&reg; 7, Windows Vista&reg;, Windows XP/2000, Mac&reg; OS X 10.4.9 & up, Linux (print only)
Standard Interface USB Device 2.0 Hi-Speed
Software Included Canon Drivers, Document Management & OCR Software
Power Consumption (approx.) 1090W (Max)
10W (Standby)
3W (Energy Saver)
Dimension (W x D x H) 15.4" (W) x 16.6" (D) x 14.6" (H)
Weight 24.5 lbs. (w/o cartridge)
25.8 lbs. (w/cartridge)
Warranty 1 year limited carry-in/exchange warranty
(Extended warranty available)
Canon imageCLASS MF4450/D550 LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Click Here to download the imageCLASS MF4450/D550 Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
