Canon Support for imageCLASS MF229dw | Canon U.S.A., Inc.
imageCLASS MF229dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 04.07.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 08.29.14
File Size 12.26 MB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 1.72 MB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
imageCLASS MF229dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF229dw
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 16ppm (2-sided plain paper letter)4
Up to 28ppm (1-sided plain paper letter)4
First Print Time 6 seconds or less (letter)5
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 600 dpi
(1200 x 1200 dpi quality)
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Watermark, Toner Saver, Page Composer
Print Memory 256 MB (Shared)
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 28cpm (letter)
Duplex Copy Speed Up to 16cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Photo, Text,
Halftones 256 Levels
Warm-up Time Approximately 13.5 seconds
First Copy Time Approximately 9 seconds8
Recovery Time Approximately 2 seconds
Maximum Number of Copies 99 copies
Reduction/Enlargement 25%, 50%, 64%, 78%129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter
ADF: Up to Legal
Copy Features Collate
2 on 1
4 on 1
ID Card Copy
Copy Memory 256 MB (Shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)9
Fax Resolution Up to 200 x 400 dpi (super fine)
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 256 sheets10
Speed Dials 100 coded dials
Group Dialing 103 destinations
Sequential Broadcasting 114 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Activity Reports Activity Result & Activity Management
pC Fax Sending only
Fax Forwarding Yes
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Letter
ADF: Up to Legal
Duplex Scan Yes
Compatibility TWAIN, WIA
Scan Features Push Scan, Pull Scan
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 1-sheet multipurpose tray11
Document Feeder 50-sheet duplex11
Paper Output 100 sheets (face down)
Paper Weight 16-43 lb. bond (cassette)
16-43 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive, Statement
Media Types Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index Card
Envelope Capacity 20 envelopes
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless6
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon Mobile Printing1, Apple AirPrint&trade;2. Mopria&trade; Print Service12, Canon Mobile Scanning for Business3
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services DHCP, BOOTP, RARP, Auto IP (IPv4), Bonjour( mDNS), DHCPv6 (IPv6)
Network Management Protocols SNMPv1 (IPv4,IPv6)
OS Compatibility Windows&reg; 8.1, Windows 8, Windows 7, Windows Server&reg; 2012, Windows Server 2012 R2, Windows Server 2008 R2, Windows Server 2008, Windows Vista&reg;, Windows Server 2003, Windows&reg; XP, Mac&reg; OS X 10.5.8 & up
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, MF Toolbox, Presto! PageManager, Address Book Tool, Toner Status
Environmental Specifications
Power Consumption Max: Approx. 1,220W
During Operation: Approx. 520W
Standby: Approx. 5.8W
Energy Saver: Approx. 1.7W (wired)
Approx. 2.3 W (wireless)
Typical Energy Consumption 0.8kWh
General Specifications
Dimensions 15.4" (W) x 14.9" (D) x 14.2" (H)
Unit Weight (without/with cartridge) 28.9 lbs. (w/o cartridge)
30.2 lbs. (w/cartridge)
Package Weight Approx. 38.6 lbs.
Cartridge Type Cartridge 137 (Yields approximately 2,400 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 6-line BW LCD Touch
Duty Cycle Up to 10,000 pages per month
Security IP Filtering, MAC Address Filtering
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty13 (Extended warranty available)
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.usa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666),
Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
