Canon Support for imageCLASS LBP6650dn | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.16.10
File Size 7.23 MB
Date 05.07.13
File Size 1.21 MB
Date 12.22.17
File Size 940.90 KB
Date 10.04.19
File Size 958.35 KB
Date 04.07.25
File Size 1.85 MB
Date 01.31.23
File Size 2.26 MB
Date 09.17.24
File Size 1.85 MB
Date 09.30.16
File Size 717.77 KB
Date 12.02.20
File Size 961.90 KB
Date 12.20.23
File Size 1.85 MB
Date 01.31.23
File Size 2.16 MB
Date 03.27.17
File Size 716.21 KB
Date 09.18.18
File Size 948.95 KB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
Printer
Printing Method Monochrome Laser
Print Speed (up to) Black:Up to 35 ppm (letter)1
Print Resolution (Up to) Up to 600 x 600 dpi (2400 x 600 dpi quality)
Toner Compatibility (for Laser MFP) Canon Cartridge 119
CRG Yield* (2,100)
Canon Cartridge 119 II Hi-Capacity
CRG Yield* (6,400)
*Yield based on ISO/IEC Standard
Buffer/Ram Standard Print Memory: 128 MB (Stationary RAM: 64 MB + Expansion RAM: 64 MB)
Maximum Print Memory: 320 MB (Stationary RAM: 64 MB + Expansion RAM: 256)3
Paper Compatibility Plain Paper, Heavy Paper, Transparency, Label, Index Card, Envelope, Postcard
Printer Features Print Modes
Toner Saver, Booklet, Poster, Watermark
Printer Language
Printer Language UFRII, PCL 5e/6 (45 fonts), PS Level 3 Emulation (45 fonts)
Paper Handling 250-sheet cassette, 50-sheet multipurpose tray2
Optional: 500-sheet cassette2
Paper Weights 16 to 32 lb. bond (cassette), 16 to 43 lb. bond (multipurpose tray)
Output Tray Capacity 150 sheets (face down)2
General
OS Compatibility Windows&#174; 7, Windows Server&#174; 2008, Windows Vista&#174;, Windows Server 2003, Windows XP/2000, Mac&#174; OS X (version 10.4.9 & up), Citrix XenApp 6.0 (64 bit), XenApp 5.0 (32 bit), Presentation Server 4.5 (32 bit/64 bit), XenDesktop 4.0/3.0/2.1/2.0 (32 bit/64 bit)
Standard Interface USB Device 2.0 Hi-Speed
10/100 Base T Ethernet
Software Included Canon Drivers, NetSpot Device Installer
Power Consumption (approx.) Max: 1,120W or less
Standby: approx. 9W
Energy Saver: approx. 5 W
Dimension (W x D x H) 15.8" (W) x 14.9" (D) x 10.6" (H)
Weight 25.6 lbs. without cartridge; 27.4 lbs. with cartridge
Noise During operation: 54.9 dB or less (sound pressure), 70.6 dB or less (sound power)
During standby: Inaudible (sound pressure), 43 dB or less (sound power)
Warranty 1 year limited exchange warranty5
(Extended warranty available)
CANON imageCLASS LBP6000 LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to your Canon imageCLASS LBP6000 packaged with this limited warranty (the "Product"). The Product, when delivered to the original purchaser or the person for whom it was purchased as a gift (the "Purchaser") in new condition in the original container, is warranted against defective materials or workmanship, under normal use and service, for a period of one (1) year from the date of purchase. During the warranty period, Canon USA shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or exchange the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to consumables such as paper, as to which there shall be no warranty or replacement. THIS LIMITED WARRANTY DOES NOT COVER THE CARTRIDGE FOR WHICH A SEPARATE WARRANTY IS GIVEN. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE CARTRIDGE LIMITED WARRANTY.
The Product covered by this Limited Warranty will be exchanged or repaired by Canon or an authorized service provider (the "Service Provider"). To arrange for service for the Product under warranty, please call:
In the United States:
    Your local Service Provider; or call
    1-800-828-4040, Monday through Friday from 8:00 a.m. to 8:00 p.m., E.T., except holidays.
If the Product malfunction is not covered by this Limited Warranty or the warranty period has expired or eligibility for warranty coverage has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then-current service call rates of Canon USA or the Service Provider.
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH, OR FOR THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered. NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA, CANON USA AFFIALIATES, NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR FOR ANY OTHER SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU.) THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT AND STATES YOUR EXCLUSIVE REMEDY.
    This warranty gives you specific legal rights, and you may have other rights, which vary from state to state.
    * Support programs are subject to change without notice.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Incompatibilities between Mac OS X Lion (10.7) and our previously released Mac OS X 10.6 Printer and Fax drivers
Advisory Type
Date 07.27.11
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
