Canon Support for Extender EF 1.4X III | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.25.11
File Size 89.20 KB
Focal Length & Maximum Aperture
Magnification: 1.4x
Lens Construction
7 elements in 3 groups
Max. Diameter x Length, Weight 2.8 x 1.1 in, 7.9 oz. / 72.0 x 27.2mm, 225g
Note This lens is only compatible with fixed focal length L-series lenses 135mm and over, as well as the EF 70-200/2.8L, EF 70-200/2.8L IS, EF 70-200/4L, and EF 100-400/4.5-5.6L.
Canon EF Lenses Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase
A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider in their sole discretion. Replaced parts and exchanged Products will become the property of Canon.
When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair.
This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases:
a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
b) If a Product is defective as a result of leaking batteries or liquid damage.
(c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider.
(d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
(e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
(f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
Canon Canada Inc., 8000 Mississauga Road, Brampton, Ontario, L6Y 5Z7
Canon Sales and Service Center
Canon USA
One Canon Park,
Melville, NY 11747,USA
Tel: (1)-800-828-4040
Canon Canada Inc,
Brampton, Ontario, L6Y 5Z7, Canada
(1)-800-652-2666
Online Repair
Title Canon Support | Firmware Notice: EF 70-200mm f/4L IS II USM: Firmware Version 1.0.7
Advisory Type
Date 09.11.18
Title Canon Support | Firmware Notice: EF 100-400mm f/4.5-5.6L IS II USM: Firmware Version 1.0.7
Advisory Type
Date 11.03.20
Title Canon Support | Service Notice: The EF200 f/2L IS USM and EF800mm f/5.6L IS USM Lenses with the Canon EOS 5D Mark III Digital SLR Camera
Advisory Type
Date 06.22.14
Title Canon Support | Service Notice: Drop-in Circular Polarizing Filters PL-C52 (WII) & PL-C52
Advisory Type
Date 02.22.16
Title Canon Support | Firmware Notice: Firmware Update for EF300mm f/2.8L IS II USM, EF400mm F2.8L IS II USM, EF500mm f/4L IS II USM and EF600mm f/4L IS II USM
Advisory Type
Date 09.16.14
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
