Canon Support for EOS Rebel SL2 | Canon U.S.A., Inc.
EOS Rebel SL2
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
Digital AF/AE single-lens reflex camera with built-in flash
Recording Media
SD/SDHC/SDXC memory cards
  • SD speed class-compatible
  • UHS-I compatible
  • High-speed writing is supported when a UHS-I compatible SD card is used.
  • Compatible with Eye-Fi cards.
  • Multimedia cards (MMC) cannot be used (card error will be displayed).
Image Format
Approx. 22.3 x 14.9mm (APS-C)
Compatible Lenses
Canon EF lenses (including EF-S lenses, excluding EF-M lenses)
Lens Mount
Canon EF mount
Type
CMOS sensor (supporting Dual Pixel CMOS AF)
Pixels
Approx. 24.2 megapixels
Pixel Unit
Approx. 3.72 &micro;m square
Total Pixels
Approx. 25.8 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • Self-cleaning activated automatically (taking approx. 2 sec.) when power is turned on or off. Manual operation also possible (taking approx. 8 sec.).
    • After the cleaning is performed, the camera will automatically restart (Power OFF to ON).
    • When you use Multi Shot Noise Reduction, Clean now cannot be selected.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
  3. Manual cleaning (by hand)
Recording Format
Compliant to Design rule for Camera File system 2.0 and Exif 2.3
File Size
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
RAW: 6000 x 4000
4:3 Aspect Ratio
Large: 5328 x 4000*
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600*
RAW: 6000 x 4000
16:9 Aspect Ratio
Large: 6000 x 3368*
Medium: 3984 x 2240*
Small 1: 2976 x 1680*
Small 2: 2400 x 1344*
RAW: 6000 x 4000
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
RAW: 6000 x 4000
* Indicate an inexact proportion.
File Numbering
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Simultaneous recording is possible using a combination of RAW and JPEG/Large(Fine).
Color Space
sRGB/Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1?3
    • In Basic Zone modes, [Auto] will be set for and of the mode, and [Standard] will be set for other modes.
    • In Creative Zone modes, you can select or set the Picture Style.
    • [Auto] is the default setting for [User Def. 1?3].
Settings
  1. Auto (Ambience priority/White priority)
  2. Daylight
  3. Shade
  4. Cloudy*
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
* Effective also in twilight and sunset.
Auto White Balance
Option between ambience priority and white priority settings
Color Temperature Compensation
Blue/amber bias: &plusmn;9 levels
Magenta/green bias: &plusmn;9 levels
Corrected in reference to the current WB modes color temperature.
Type
Eye-level SLR (with fixed pentamirror)
Coverage
Approx. 95% vertical/horizontal coverage (at approx. 19mm eye point and Large image size)
Magnification
Approx. 0.87x/24.5&deg; (with 50mm lens at infinity, -1 m-1)
Eye Point
Approx. 19 mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
Adjustable from approx. -3.0 to +1.0 m-1 (dpt)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60)
Viewfinder Information
Spot metering circle, AF point activation indicator, AF point, ISO speed indicator, Focus indicator, Maximum burst, ISO speed, Highlight tone priority, Exposure level indicator, Exposure compensation amount, AEB range, Red-eye reduction lamp ON, Exposure compensation, Aperture, Shutter speed, Bulb exposure, FE lock, Busy, Built-in flash recharging, No card warning, Card error, Card full warning, error code, Flash exposure compensation, High-speed sync, FE lock / FEB in-progress, Flash-ready, Improper FE lock warning, AE lock, AEB in-progress, Warning icon
Depth Of Field Preview
Provided with depth of field preview button
Type
TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
AF Points
9 points
Center AF point is AF cross-type supporting f/5.6.
Center AF point is vertical line-sensitive supporting f/2.8.
Other AF points is vertical line-sensitive or horizontal line-sensitive AF supporting f/5.6.
AF Working Range
With One-Shot AF, at 73°F/23°C, ISO 100
EV -0.518 (center AF point)
EV 0.518 (other AF points)
(Based on Canon&rsquo;s testing standards and environment)
Focusing Modes
  1. Autofocus
    1. One-Shot AF
    2. Predictive AI Servo AF
    3. AI Focus AF
      • Switches between One-Shot AF and AI Servo AF automatically.
  2. Manual focus
AF Point Selection
  1. Manual selection
  2. Auto selection
    • Manually selectable in Basic Zone modes (except Special Scene Candlelight and Creative Filters Fish-eye effect and Miniature effect)
AF Assist Beam
  1. Enable
  2. Disable
  3. Enable external flash only
  4. IR AF assist beam only
Metering Modes
63-zone metering sensor
  1. Evaluative metering (linked to all AF points)
  2. Partial metering (center, approx. 9.0% of viewfinder)
  3. Spot metering (center, approx. 4.0% of viewfinder)
  4. Center-weighted average metering
Metering Range
EV 1.0 - EV 20.0 (at 73&deg;F/23&deg;C, ISO 100, evaluative metering)
Exposure Control Systems
  1. Creative Zone
    1. Program AE (shiftable)
    2. Shutter-priority AE
    3. Aperture-priority AE
    4. Manual exposure (including bulb)
  2. Basic Zone
    1. Scene Intelligent Auto (Program AE/ non-shiftable)
    2. Flash Off
    3. Creative Auto
    4. Special Scene
      1. Portrait
      2. Group Photo
      3. Landscape
      4. Sports
      5. Kids
      6. Close-up
      7. Food
      8. Candlelight
      9. Night Portrait
      10. Handheld Night Scene
      11. HDR Backlight Control
    5. Creative Filters
      1. Grainy B/W
      2. Soft Focus
      3. Fish-eye effect
      4. Water painting effect
      5. Toy camera effect
      6. Miniature effect
      7. HDR art standard
      8. HDR art vivid
      9. HDR art bold
      10. HDR art embossed
ISO Speed Range
Normal ISO 10025600 (in whole-stop increments)
Expanded ISO 51200
  • For [Highlight tone priority], the minimum ISO speed limit will be ISO 10025600.
Exposure Compensation
Manual ±5 stops in 1/3- or 1/2-stop increments*
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock
  1. Auto AE lock
    • In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
  2. Manual AE lock
    • In the P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
    • Possible with all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
  • Electronic 1st curtain and mechanical 2nd curtain
Shutter Speeds
1/4000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.)
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay, continuous shooting after 10 sec. (2 to 10 shots)
Shutter Lag Time
With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec.
  • Time lag with the aperture stopped down by 3 stops or less from the open aperture.
Flash Metering
E-TTL II autoflash (Evaluative, Average), FE Lock
Flash Exposure Compensation
&plusmn;2 stops in 1/3- or 1/2-stop increments
  • Flash exposure compensation for built-in flash and external Speedlite can be set from the camera.
FE Lock
Provided
External Flash Settings
The camera can set the following with EX series Speedlites:
  • The actual setting options will differ depending on the Speedlite used.
  1. External flash control
    • Flash firing, E-TTL II metering, Flash mode, Wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings.
    • The radio wireless flash functions can be set from the camera.
  2. External flash Custom Function setting
    • The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive Modes and Continuous Shooting Speed during Viewfinder Shooting
  1. Single shooting
  2. High-speed continuous shooting
    • Max. approx. 5.0 shots/sec. (One-Shot AF and AI Servo AF)
    • Maximum continuous shooting speed with 1/500 sec. or faster shutter speed, maximum aperture (varies depending on the lens), with a fully-charged Battery Pack LP-E17 and at room temperature (73°F/23°C).
    • With the AF mode set to One-Shot AF and the Image Stabilizer turned off when using the following lenses: EF 300mm f/4L IS USM, EF 28135mm f/3.55.6 IS USM, EF 75300mm f/45.6 IS USM, EF 100400mm f/4.55.6L IS USM.
  3. Silent single shooting
  4. Silent continuous shooting
    • Max. approx. 2.5 shots/sec.
  5. Self-timer: 10 sec./remote control
    • Compatible with Wireless Remote Controller BR-E1.
    • Incompatible with accessories using the infrared transmission system as Remote Controller RC-6.
  6. 2 sec. self-timer
  7. Continuous shooting after 10 sec. self-timer (2 to 10 shots)
Shooting Modes
Still photo shooting and video shooting
Focusing
  1. Dual Pixel CMOS AF
    • Dual Pixel CMOS AF is possible with all EF and EF-S lenses.
    • Contrast AF is not provided.
  2. Manual focus
    • Magnifying the image by 5x or 10x for manual focus possible.
Metering Modes
Real-time metering with image sensor
  • AE lock possible. The metering timer setting can be changed.
  1. Evaluative metering (315-zone)
  2. Partial metering (center, approx. 6.0% of Live View screen)
  3. Spot metering (center, approx. 2.6% of Live View screen)
Metering Range
EV 020 (at 73&deg;F/23&deg;C, ISO 100, evaluative metering)
Grid Display
  1. Off
  2. 3x3
  3. 6x4
  4. 3x3+diag
File Format
MP4
Video: MPEG-4 AVC / H.264
  • Variable (averaged) bit rate
Audio: AAC
MOV: ALL-I (FHD 29.97, time-lapse movies only)
Focusing
    • Contrast AF is not possible.
  2. Manual focus
    • Magnifying the image by 5x or 10x for manual focus possible (not possible during movie shooting).
Range
Full range (0-255)
Exposure Control
* In Basic Zone modes, exposure control is exerted as appropriate for the detected scene.
Up to &plusmn;3 stops in 1/3- or 1/2-stop increments
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0-inch (screen aspect ratio of 3:2)
Approx. 2.95 in./7.50cm diagonal (approx. 2.46 in./6.24cm width, approx. 1.64 in/4.16cm height)
Pixels
Approx. 1.04 million dots
Coverage
Approx. 170&deg; vertically and horizontally
Brightness Control
Adjustable to one of seven brightness levels
Coating
Clear View LCD II
  • Anti-smudge coating not applied.
  • Anti-reflection coating not applied.
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
  1. Single-image display
    • No information display
    • Basic information display
    • Detailed shooting information display
      • Basic shooting information
      • Lens information and RGB histogram
      • White balance
      • Picture Style and sharpness
      • Contrast, color saturation and color tone
      • Color space and noise reduction
      • Lens aberration correction
      • GPS information (when GPS Receiver is used)
  2. Index display
    • 4-image
    • 9-image
    • 36-image
    • 100-image
Highlight Alert
With detailed information display, overexposed highlight areas with no image data will blink.
Histogram
Brightness and RGB
Items
Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in a folder
  4. All images in a card
  5. All found images (only during image search)
Erase
Except protected images
  1. Select image to erase
  2. Select range
Compatible Printers
Images can be sent via Wi-Fi&reg; to a PictBridge-compatible (Wireless LAN) printer and printed.
DPOF
Complies to DPOF Version 1.1
Standards Compliance
IEEE 802.11b/g/n
Transmission Method
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transmission Range
Approx. 15 m/49.2 ft.
*When communicating with a smartphone or tablet
*With no obstructions between the transmitting and receiving antennas and no radio interference
Transition Frequency (Central Frequency)
Frequency: 24122462 MHz
Channels: 111 channels
Connection Method
Camera Access Point Mode and Infrastructure mode
Security
Authentication method: Open system, Shared key, WPA/WPA2-PSK
Encryption: WEP, TKIP, AES
Communication with a Smartphone
Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible.
Images can be sent to a smartphone.
Transfer Images Between Cameras
Transferring one image, Transferring selected images, Transferring resized images
Connect to Connect Station
Images can be sent to and saved on Connect Station.
Remote Operation Using EOS Utility
Remote control functions and image viewing functions of EOS Utility can be used wirelessly.
Print from Wi-Fi® Printers
Images can be sent to a Wi-Fi® printer.
Send Images to a Web Service
Images in the camera or links to images can be sent to registered Web services.
NFC Forum Type 3/4 Tag compliant (dynamic)
Bluetooth® Specification Version 4.1 compliant (Bluetooth® low energy technology)
Transmission Method
GFSK modulation
Custom Functions
11 Custom Functions settable with the camera
Custom Controls
Functions can be assigned to the following control parts:
  • Shutter button (halfway pressing)
  • AE lock button
  • SET button
My Menu Registration
Up to six items from the menu items and the top-tier items of Custom Functions can be registered to each tab.Up to five My Menu tabs can be added.
My Menu tab overall operations
  • Adding a tab
  • Deleting tabs in a batch
  • Deleting all tab items
  • Setting the menu display
My Menu tab detailed operations
  • Selecting item to register
  • Sorting registered items
  • Deleting selected registered items
  • Deleting registered items in a batch
  • Deleting tabs
  • Changing a tab name (16 ASCII characters)
USB Terminal
Hi-Speed USB (USB 2.0)
  • For PC communication
  • For Connect Station connection
Video Out Terminal
Type C (Resolution switches automatically)
  • Video is not displayed unless the video system is correctly set for the connected TV set, [NTSC] or [PAL].
Extension System Terminal
3.5mm diameter stereo mini jack
  • Directional Stereo Microphone DM-E1 connection
Battery
Battery Pack LP-E17 x 1
  • With the AC Adapter AC-E6N and DC Coupler DR-E18, AC power operation is possible.
Battery Life
Mode Shooting Method Battery Temperature Possible Shots (Approx.)
AE 100% AE 50% / FA 50%
Camera body only Viewfinder shooting LP-E17 At 73°F/23°C 840 650
At 32°F/0°C 770 620
Live View shooting LP-E17 At 73°F/23°C 290 260
At 32°F/0°C 260 240
Battery Check
Automatic battery check when the power switch is turned ON. Displayed in 4 levels.
Power Saving
Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses.
* Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc.
Date/Time Battery
Built-in secondary batteryWhen fully-charged, the date/time can be maintained for approx. 3 months
  • Recharge time: approx. 8 hrs.
    • To become capable to maintain the right date/time for 3 months after main battery power depletion.
Start-up Time
Approx. 0.2 sec. (based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 4.82 x 3.65 x 2.75 in. (122.4 x 92.6 x 69.8mm)
  • CIPA compliant.
Weight
Approx. 15.98 oz. / 453g (Including battery and card)
Approx. 14.32 oz. / 406g (Body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Firmware Notice: EOS Rebel SL2: Firmware Version 1.0.1
Advisory Type
Date 11.27.17
Title Canon Support | Firmware Notice: EOS Rebel SL2: Firmware Update, Version 1.0.3
Advisory Type
Date 02.12.20
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS Rebel SL2: Firmware Version 1.1.0
Advisory Type
Date 10.18.20
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
