Canon Support for EOS M | Canon U.S.A., Inc.
EOS M
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.19.12
File Size 10.59 MB
Date 09.18.12
File Size 8.42 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 09.18.12
File Size 38.04 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
CMOS Sensor
Pixels
Effective pixels: Approx. 18.0 megapixels
Pixel Unit
4.3 &micro;m square
Total Pixels
Total pixels: Approx. 18.50 megapixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the CMOS sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit
- Removes dust adhering to the low-pass filter.
- Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.).
(2) Dust Delete Data acquisition and appending
- The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
- The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
Recording Format
Complies with Design rule for Camera File system 2.0 and Exif 2.30
File Size
(1)Large: Approx. 17.90 Megapixels (5,184 x 3,456)
(2)Medium: Approx. 8.00 Megapixels (3,456 x 2,304)
(3)Small 1: Approx. 4.50 Megapixels (2,592 x 1,728)
(4)Small 2: Approx. 2.50 Megapixels (1920 x 1280)
(5)Small 3: Approx. 350,000 Pixels (720 x 480)
(6)RAW: Approx. 17.90 Megapixels (5,184 x 3,456)
Backup Recording
N/A
File Numbering
The following three types of file numbering method can be set:
(1) Continuous numbering
* The numbering of captured images will continue even after you replace the camera's card.
(2) Auto reset
* When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
(3) Manual reset
* Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
RAW and JPEG Large images are recorded simultaneously
Color Space
sRGB, Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto (Approx. 3,000&deg; - 7,000&deg;K), Daylight (Approx. 5,200&deg;K), Shade (Approx. 7,000&deg;K), Cloudy, Twilight and Sunset (Approx. 6,000&deg;K), Tungsten Light (Approx. 3,200&deg;K), White Fluorescent Light (Approx. 4,000&deg;K), Flash, Custom (Custom White Balance: Approx. 2,000&deg; - 10,000&deg;K)
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance correction:Blue/amber bias: &plusmn;9 levels Magenta/green bias: &plusmn;9 levels* Correction based on the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
No Viewfinder.
Type
TTL-CT-SIR AF-dedicated CMOS sensor
AF Points
31 points (maximum)
AF Working Range
EV 1 to 18 (at 73&deg;F/23&deg;C, ISO 100)
Focusing Modes
With Canon EF-M Lenses:
(1) Autofocus
- One-Shot AF or Servo AF
(2) Manual focus (MF)
(3) AF + MF (manual focus after One-Shot AF)
AF Point Selection
(1) Manual selection
(2) Auto selection
* Automatically set in Basic Zone modes.
Selected AF Point Display
Provided
AF Assist Beam
Provided
Effective range: Approx. 8.2 ft./ 2.5m. at center
* With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
* Compatible with assist beam (intermittent firing) of 320EX flash.
Metering Modes
Real-time evaluative metering with image sensor
Evaluative metering, partial metering (center: approx. 11%), spot metering (center: approx. 2.8%), center-weighted average metering
* AE lock possible. The active metering time can be changed.
Metering Range
EV 1.0 - EV 20.0 (at 73&deg;F/23&deg;C, EF-M 22mm f/2 STM, ISO 100)
Exposure Control Systems
Creative Zone
(1) Program AE (shiftable)
(2) Shutter-priority AE
(3) Aperture-priority AE
(4) Manual exposure (including bulb)Basic zone
(1) Creative Auto
(2) Portrait
(3) Landscape
(4) Close-up
(5) Sports
(6) Night Portrait
(7) Handheld Night Scene mode
(8) HDR Backlight Control mode
ISO Speed Range
For Video:
Manual Setting range of ISO 100-6400, expandable to ISO 12800
For Stills:
1.Manual setting range of ISO 100-12800, expansion to ISO 25600
2.Auto, ISO 100-6400 (in whole-stop increments)
- In Creative Zone modes, the maximum ISO speed (ISO 400, 800, 1600, 3200, or 6400) for ISO Auto can be set.
- With C.Fn-6-1 (Highlight tone priority), ISO 200 or higher will be set.
*1: Fixed at ISO 400 for Bulb exposures.
*2: Depends on the maximum ISO speed that has been set.
*3: If fill-flash will result in overexposure, the lowest ISO 100 is set.
*4: When using bounce flash with an external Speedlite in a Basic Zone mode or P mode, the ISO speed is set automatically within 400&ndash;1600 (or the maximum limit).
Exposure Compensation
Manual: &plusmn;3 stops in 1/3- or 1/2-stop increments
AEB : &plusmn;2 stops in 1/3- or 1/2-stop increments
* Manual exposure compensation and AEB can be set in combination.
* AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure.
* If AEB is used with the self-timer, the three bracketed shots will be taken in succession after the 10-sec. or 2-sec. delay.
AE Lock
(1) Auto AE lock
* In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) Manual AE lock
* In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.)
* Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds
1/4000 to 1/60 sec., X-sync at 1/200 sec. (Scene Intelligent Auto)
1/4000 to 30 sec., bulb, X-sync at 1/200 sec. (Total shutter speed range. Available range varies by shooting mode.)
* Settable in 1/3- or 1/2-stop increments.
Shutter Release
Soft-touch electromagnetic release
Self Timer
Shutter Lag Time
(1) During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.05 sec.
(2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.2 sec.
* Time lag with the aperture stopped down by 3 stops or less. Excludes AF operation time.
Type
Not available*
*For flash photography, Speedlite flashes are required for the EOS M Digital Camera.
Flash Metering
E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop or 1/2-stop increments
FE Lock
Provided
PC Terminal
Not Provided
Drive Modes
Single, Continuous, 10-sec. self-timer/Remote control, 2-sec. self-timer, Continuous shooting after 10-sec. self-timer (2 to 10 shots)
Continuous Shooting Speed
With One-Shot AF or MF: Approx. 4.3 fps*
*With Servo AF during continuous shooting, there are limitations depending on AF operation and the attached lenses.
With One-Shot AF or MF: Approx. 4.3 fps&#8727;
&#8727;With Servo AF during continuous shooting, there are limitations depending on AF operation and the attached lenses.&#8727;1AF frame is fixed in frame chosen by &#91;Face Detect + Tracking&#93; and &#91;FlexiZone - Multi&#93; at the time of continuous shooting mode, and AF is carried out for the chosen AF frame.
Maximum Burst
Based on 8GB memory Card*1:
JPEG Large/Fine: Approx. 15 Shots
RAW: Approx. 6 Shots
RAW+JPEG Large/Fine: 3 Shots
Based on UHS-I 8GB memory card*2:
JPEG Large/Fine: Approx. 17 Shots
RAW + JPEG Large/Fine: 3 Shots
*1 Figures are based on Canon's testing standards (ISO 100 and "Standard" Picture style)
*2 Figures are based on Canon's testing standards (ISO 100 and "Standard" Picture style)
Shooting Modes
Photo shooting and video shooting
Focusing
(1) Autofocus
- Face Detection + Tracking AF
- FlexiZone - Multi (31 zones, AF at the touched Zone)
- FlexiZone - Single
Metering Modes
Evaluative metering, partial metering, spot metering, center-weighted average metering
Metering Range
EV 1 - EV 20 (At 73&deg;F/23&deg;C, EF-M 22mm f/2 STM, ISO 100)
Grid Display
Provided (Two-type grid displays)
Exposure Simulation
Provided
Silent Shooting
Not provided
File Format
MOV (Image data: H.264; audio: Linear PCM (Stereo))
File Size
Recording Size:
[Full HD]
1920 x 1080: 330 MB/min.
[HD]
1280 x 720: 330 MB/min.
[SD]
640 x 480: 82.5 MB/min.
Frame Rates
1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p
1280 x 720 (HD): 60p (59.94) / 50p
640 x 480 (SD): 30p (29.97) / 25p
Continuous Shooting Time
Based on 8GB Memory card
[1920 x 1080]
30 fps: Approx. 22 min.
25 fps: Approx. 22 min.
24 fps: Approx. 22 min.[1280 x 720]
60 fps: 22 min.
50 fps: 22 min.[640 x 480]
30 fps: 1 hr. 32 min.
25 fps: 1 hr. 32 min.
Based on 16GB Memory card
[1920 x 1080]
30 fps: Approx. 44 min.
25 fps: Approx. 44 min.
24 fps: Approx. 44 min.[1280 x 720]
60 fps: 44 min.
50 fps: 44 min.[640 x 480]
30 fps: 3 hr. 4 min.
25 fps: 3 hr. 4 min.
Focusing
1. Face Detection + Tracking AF
2. FlexiZone - Multi
3. FlexiZone - Single
Range
For Videos:
Auto ISO range: ISO 100-6400
Manual ISO range: ISO 100-6400 (expandable to 12800 in H mode)
*If highlight tone priority is set, automatically set within ISO 200 or higher.
Exposure Control
(1) Movie autoexposure mode
* Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set.
(2) Movie manual exposure mode
* Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps.
Provided (&plusmn;3 stops in 1/3-stop increments)
* For video, exposure compensation will not be applied beyond &plusmn;3 stops even if the exposure compensation has been set beyond &plusmn;3 stops.
Type
TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type)
Monitor Size
3.0 in. (Screen aspect ratio of 3:2)
Pixels
Approx. 1,040,000 dots
Coverage
Viewing Angle: 170&deg; (vertically and horizontally)
Brightness Control
Adjustable to one of 7 levels
Coating
Anti-smudge coating
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
(1) Single image display
- Single image, basic information, detailed information, histogram display
(2) Index display
4-image index and 9-image index.
(3) Jump display (Image jump w/ Main Dial)
1/10/100 images, shooting date, by folder, videos, stills, ratings
Highlight Alert
On the detailed information and histogram displays, highlight areas with no image data will blink.
Items
When you press the Quick Control function button under the following conditions, you can set the functions below:
*The settable functions depend on the shooting mode(1)During still photo shooting:
AF operation, AF method, image-recording quality, Creative filters, white balance, Picture Style, Auto Lighting Optimizer, and metering mode.(2)During movie shooting:
AF method, image-recording quality (stills), movie-recording size, video snapshot, white balance, Picture Style, and Auto Lighting Optimizer.
Protection
Erase protection can be applied/canceled for a single image, all images in a folder, or all images in the card.
Erase
Erase single image, erase selected images, erase all images on folder, erase all images in a card, or erase only unprotected images.
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG images complying to Design rule for Camera File System RAW images printable. Video cannot be printed.
DPOF
DPOF print ordering provided (Complies to DPOF Version 1.1)
* If both Standard and Index are set, only Standard will take effect for printing.
Compatible Images
Not Provided
Custom Functions
Seven Custom Functions with 19 settings settable with the camera
Custom Controls
Not Provided
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered
USB Terminal
For personal computer communication and direct printing (USB 2.0 Hi-Speed)
Video Out Terminal
(1) Video OUT terminal: NTSC/PAL selectable
(2) mini-HDMI OUT terminal
Extension System Terminal
Not Provided
Battery
One Battery Pack LP-E12
* With the AC Adapter Kit ACK-E12, AC power is possible.
Battery Life
1) Camera Battery Pack LP-E12
Battery Check
Automatic battery level check when power is turned ON.
Battery level indicated in one of four levels on LCD monitor.
Power Saving
Power turns off after the set time of non-operation elapses
* [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable
Date/Time Battery
Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months.
Start-up Time
Approx. 1.6 sec. with EF-M 18-55mm f/3.5-5.6 IS STM* (Based on CIPA standards)
*The times are different according to the attached lens.
Dimensions (W x H x D)
Approx. 4.28 x 2.62 x 1.27 in./ 108.6 x 66.5 x 32.3mm
Weight
Approx. 9.2 oz. / 262g (body only)
Approx. 10.5 oz. / 298g (According to CIPA Standards)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or less
All data are based on Canon's Standard Test Method. Subject to change without notice.
If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker.
Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
