Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Sensor
CMOS Sensor with Global Shutter
Total Pixels
Approx. 10.92 megapixels (4374 x 2496)
Number of Effective Pixels
Approx. 8.85 megapixels (4096 x 2160):
When 4096 x 2160 or 2048 x 1080 is selected as the resolution
Approx. 8.29 megapixels (3840 x 2160):
When 3840 x 2160 or 1920 x 1080 is selected as the resolution
RAW Recording Pixels 4272x 2376
Lens Mount
PL mount
Exposure Modes
Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
Shutter Setting
Speed, Angle, Clear Scan, Slow, or Off mode selected
Either 1/3 or 1/4 steps selected as speed increment
Iris Setting
Manual
ISO
4K 60fps or lower/2K crop 120fps or lower:
[*400 - 640 - 25600 - 102400*]
4K over 60fps/2K crop over 120fps:
*When the sensitivity is expanded
ND Filter
5 density settings (2, 4, 6, 8*, 10* stops)
*when expansion is selected
Focus Control
Manual Focus
Controls Display
3.0-inch (7.66cm on the diagonal) color liquid crystal
Approximately 1.036 million dots
Viewfinder
FHD 1920 x 1080 0.7"
Optional OLED Electronic View Finder (EVF-V70) sold separately
White Balance
Kelvin setting (setting range: 2000K to 15000K/ -20CC to +20CC), AWB, daylight, tungsten, settings (A/B)
Frame Rate
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode: 59.94i/59.94P/29.97P/23.98P
50.00 Hz mode: 50.00i/50.00P/25.00P
24.00 Hz mode: 24.00P
CFast Card (2 slots)
Movie recording (XF-AVC/ProRes), custom pictures, metadata recording
SD Card
Records movies XF-AVC (proxy), photos (JPEG), custom pictures, metadata, menus and other data
Codex Capture Drive
Video (RAW) (Available with Codex Recorder Attached to C700) / ProRes*
*with March 2017 update
Video
(1) XF-AVC/ MPEG-4 AVC/H.264
(2) ProRes/ Apple ProRes Codec
(3) RAW / Uncompressed
Audio
Linear PCM (24 bit- 48kHz)
4-Channel Recording
Resolution/Sampling
4096x2160 YCC422 10 bit/3840x2160 YCC422 10 bit
2048x1080 YCC422 10 bit/1920x1080 YCC422 10 bit
2048x1080 RGB444 12 bit/1920x1080 RGB444 12 bit
2048x1080 RGB444 10 bit/1920x1080 RGB444 10 bit
Bit Rate
810/440/410/310/225/210/170/160/ 90Mbps Intra-frame
50 Mbps Long GOP
Resolution/Sampling
4096x2160 YCC422 10bit/3840x2160 YCC422 10bit
2048x1080 YCC422 10bit/1920x1080 YCC422 10bit
2048x1080 RGB444 12bit/1920x1080 RGB444 12bit
Bit Rate
ProRes4444XQ / ProRes4444 / ProRes422HQ /ProRes422
Resolution/Sampling
2048x1080 YCC420 8 bit/1920x1080 YCC420 8 bit
Bit Rate
24/35Mbps Long GOP
Bit Depth
12/10 bit
Resolution
4096x2160, 4272x2376
S&F CROP: 2048x1080
Count-Up
Drop frame* or non-drop frame
*Only in the 59.94 Hz mode
Operation Mode
Rec run, free run, regeneration
Gamma
Canon Log 3 / Canon Log 2 / Canon Log / Wide DR
Color Space
Cinema Gamut / BT.2020 Gamut /DCI-P3 Gamut/BT.709 Gamut
LUT
BT.709/ BT.2020/ DCI/ ACESproxy/HDR-ST2084 and others
Others
Slow & Fast motion recording (max. 240 fps supported), relayrecording, double slot recording, custom picture settings,color bar, peaking display, zebra display, My Menu settings, waveformmonitor display, custom function, assignable buttons, key lock, markerdisplays, enlarged display, custom display, Browser Remote control using WFT unit, peripheral illumination correction, monaural microphone, fan control, magnification chromatic aberration compensation, GPS information recording, etc.
Playback Operations
Normal playback, frame forward, frame reverse
Clip Display
List display of clip file names
Clip Information Display
Clip metadata display, custom picture data display
Edit
Clip deletion
Input
GENLOCK terminal (also serves as SYNC OUT terminal), TIMECODE terminal (input/output switching), REMOTE terminals (A/B),MIC jack, XLR: 2 sets
Output
MON. (1/2) terminals, SDI-OUT terminal (4 sets), HDMI OUT terminal,headphones jack, SYNC OUT terminal (also serves as GENLOCKterminal), TIME CODE terminal (input/output switching), VIDEO terminal
Input/Output Control
LENS terminal, Ethernet terminal, CTRL terminal
Input
DC IN 12V jack (XLR 4-pin jack)
Output
DC 24V 2A/DC 12V 2A terminal / D-TAP terminal
Image Processing Platform
Triple Digic DV 5
Related Accessories
EVF-V70, UN-5/UN-10, OU-700, SU-15, SG-1, UC-V75, UC-V1000, MO-4E / MO-4P, RC-V100, WFT-E6A, WFT-E8A, GP-E1
Third-Party Products
(1) Codex
CDX-36150 (Codex Recorder for Canon EOS C700) / Removable Capture Drive for CDX-36150
(2) IDX
V-Mount battery (Also IDX AC adapter and cable, etc.)
IP Streaming
Streams video to decoder transmission device or computer over the network.
Bit rate / Resolution / Frame Rate
9Mbps/4Mbps: 1920x1080 [59.94i/50.00i]
2Mbps: 1280x720 [29.97P/25.00P]
1.5Mbps: 720x480(/579)/[59.94i/50.00i]
Audio
MPEG-2 ACC-LC
Audio Rate
128KBbps (Variable Bit Rate)
Transfer Media
Wi-Fi / Ethernet
Protocols
UDP, RTP, RTP + FEC, RTSP + RTP
Error Correction
FEC
Standards
IEEE 802.11b/g/n (2.4 GHz band),IEEE 802.11a/n (5 GHz band)
Transmission Frequencies and Channels
IEEE 802.11b/g/n (2.4 GHz band), 2412-2462MHz, 1-11ch (US, Canada, Korea, Taiwan, Philippine, Mexico, Saint Pierre, Miquelon, Brazil)
2412-2472 MHz, 1-13ch (in countries other than the ones listed above)
IEEE 802.11n/11a (5 GHz band): Differs depending on the models destination.
Wi-Fi Setup Method
(1) WPS [Wi-Fi Protected Setup] (push-button system, PIN code system)
(2) Manual Setup
(3) Search for Access Points
Authentication Systems
Open system, WPA-PSK, WPA2-PSK
Encryption
WEP-64, WEP-128, TKIP, AES
Dimensions (W x H x D)
Approx. 6.6 x 6.1 x 13.2 in
(167 x 154 x 336mm)
Weight
Approx. 3600 g (7.9 lb)
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Advantages of the Global Shutter Table
GS Conversion Service
What is the Sensor Change Service?
Canon’s sensor change service offers EOS C700 & EOS C700 PL owners the opportunity to convert their standard sensor for the Global Shutter sensor. The Global Shutter sensor offers incredible performance at 4.2K Resolution with 14 stops of resolution at its base ISO.
The table on the left details the advantages of the Global Shutter.
Pricing*
 Model  Price  Note
 C700  $3,700  The cost of the conversion from EF to PL lens mount is included in the $3,700 price
 C700 PL   $2,500
*All pricing is subject to change
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-855-CINE-EOS (toll free), 1-855-246-3367
TDD: 1-866-251-3752
Email: CinemaEOS@cits.canon.com
For additional support options: pro.usa.canon.com/support
Full Frame Conversion Service
Thank you,
Canon U.S.A., Inc.
TDD: 1-866-251-3752
Title Canon Support | Firmware Notice: EOS C700 / EOS C700 PL / EOS C700 GS PL
Advisory Type
Date 09.05.17
Title Canon Support | Firmware Notice: EOS C700 GS PL: Firmware Version 1.0.1.1.00
Advisory Type
Date 09.05.17
Title Canon Support | Firmware Notice: EOS C700 GS PL: Firmware Version 1.0.4.1.00
Advisory Type
Date 06.03.18
Title Canon Support | Firmware Notice: EOS C700 GS PL: Firmware Version 1.0.2.1.00
Advisory Type
Date 12.17.17
Title Canon Support | Firmware Notice: EOS C700 GS PL: Firmware Version 1.0.3.1.00
Advisory Type
Date 04.04.18
Title Canon Support | Firmware Notice: EOS C700 GS PL: Firmware Version 1.0.5.1.00
Advisory Type
Date 12.12.18
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
