Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.13.16
File Size 849.75 KB
Date 10.21.24
File Size 56.98 MB
Date 12.13.16
File Size 2.10 MB
Date 08.08.15
File Size 6.95 MB
image icon
Camera Connect
image icon
image icon
image.canon
Sensor
CMOS sensor (single-panel) equivalent to Super 35 mm
Total Pixels
Approx. 9.84 megapixels (4206 x2340)
Number of effective pixels
Approx. 8.85 megapixels (4096 x 2160): When 4096 x 2160 or 2048 x 1080 is selected as the resolution
Approx. 8.29 megapixels (3840 x 2160): When 3840 x 2160 or 1920 x 1080 is selected as the resolution
Lens Mount
PL mount
Exposure Modes
(1) Manual exposure based on shutter setting, iris setting, ISO/gain setting, and ND filter setting
(2) Push auto iris control, auto iris control (Light metering system selection, shift possible)
Shutter Setting
Speed, Angle, Clear Scan, Slow, or Off mode selected
Either 1/3 or 1/4 steps selected as speed increment
lris Setting
1/2-stop, 1/3-stop or fine setting selected
(1) Push auto iris control
(2) Auto iris control *
* Available only with some EF lenses
ISO
1 step, 1/3 step settings
[*100 - 160 - 25600 -*102400
*When the sensitivity is expanded
Gain
Normal [*-6dB - -2dB - 42dB - *54db]
Fine: Setting in 0.5d8 step increments possible
* When the sensitivity is expanded
ND Filter
5 density settings (2,4,6,8(*), 10(*) stops) [(*) when expansion is selected]
Motorized drive
Focus Control
DAF (Dual Pixel CMOS AF) supported
Manual focus, one-shot AF, continuous AF, AF-Boosted MF (*), face detection AF (Only lenses that support AF functions can be used in any of these modes.)
*See Technical Description.
LCD Monitor
4" (10.1 cm diagonal) color wide-screen LCD with 16:9 aspect ratio
Approx. 1.23 million dots (854 x RGB x 480), 100% field of view coverage
Viewfinder
0.46" (1.18 cm on the diagonal), color organic EL display with a widescreen 16:9 aspect ratio
Approx. 1.17 million dots (1024 x RGB x 576), 100% field of view ratio
White Balance
Kelvin setting (setting range: 2000K to 15000K), daylight, tungsten, settings (A/B)
Frame Rate
59.94 Hz, 50.00 Hz, 24.00 Hz
59.94 Hz mode 59.94i / 59.94P / 29.97P / 23.98P
50.00 Hz mode 50.00i / 50.00P / 25.00P
24.00 Hz mode 24.00P
CFast Card
Movie recording, custom picture settings, metadata 2-slot
SD Card
Recording of movies and photos (JPEG), custom pictures, metadata, menus and other data possible
Video Compression Formats
MPEG-4 AVC/H.264
Audio Recording System
Linear PCM (16bit/24bit- 48 kHz - 4ch)
File Format
MXF
Bit Rate
410/310/225/210/160Mbps Intra-frame 50Mbps Long GOP
35 or 24Mbps Long GOP (for proxy recording on SD cards)
CFast Card
Intraframe recording
Resolution : 4096x2160 / 3840x2160 / 2048x1080 / 1920x1080
Color Sampling: YCC422 10bit/(*)RG8444 (12bit/10bit)
(*) Only with 2048x1080 or 1920x1080; 29.97P, 23.98P, 25.00P and 24.00P
Long GOP recording
Resolution : 2048x1080 / 1920x1080
SD Card
Movies: Long GOP recording only (*)
Color Sampling: YCC420 8bit
Photo: JPEG
(*) Proxy recording using low bit rate
Count-Up
Drop frame(*) or non-drop frame
Operation Mode
Rec run, free run, regeneration
(*) Only in the 59.94 Hz mode
Zoom Remote Controller
Canon RC-V100
Special Rec
Slow & Fast motion recording (max. 120 fps supported), frame recording, pre-recording, interval recording
Other
Relay recording, double slot recording, 4K RAW output, custom picture settings, color bar, peaking display, zebra display, My Menu settings, waveform monitor display, edge monitor display, customized functions, function assignment buttons (1 to 11), key lock, marker displays, Enlarged display, custom display Browser remote control using WFT unit, peripheral illumination correction, monaural microphone, fan control, magnification chromatic aberration compensation, GPS information recording, etc.
Playback Operations
Normal playback, fast forward (at speeds of 5x, 15x, 60x), fast reverse (at speeds of 5x, 15x, 60x), frame forward, frame reverse, forward skip, reverse skip, rec review
Clip Display
3x4 (clip) index screen
[Original, OK mark, check mark, shot mark, expand, proxy, photo (SD card) index displays available]
Clip Information Displays
Clip metadata display, custom picture data display
Edit
Clip deletion, clip copying
Body
Input
GENLOCK terminal (also serves as SYNC OUT terminal), TIME CODE terminal (input output switching), REMOTE terminal, MIC terminal, AUDIO terminal
INPUT terminal (XLR) x 2, VIDEO terminal
Output
MON. terminal, REC OUT terminal, HDMI OUT terminal, headphones terminal, SYNC OUT terminal (also serves as GENLOCK terminal), TIME CODE terminal (input output switching), VIDEO terminal
AUDIO terminal
Input/output control
Expansion system terminal (WFT/other unit)
Edit
Monitor Unit
Power Supply
14.4V DC (battery pack), 16.7 V DC (DC-IN)
Image Processing Platform
Dual Digic DV 5
Main Unit Weight
Approx. 4.4 lb (2000 g)
Dimensions (W x H x D)
Approx. 5.9 x 7.2 x 7.2 in (149 x 183 x 183 mm)- with thumb rest
CANON PROFESSIONAL DIGITAL VIDEO EQUIPMENT LIMITED WARRANTY FOR PRODUCTS
PURCHASED IN THE UNITED STATES
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Digital Video Equipment (the 'Equipment') packaged with this limited warranty and purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. The Equipment is warranted to the original end-user purchaser, when delivered in new condition in its original container, under normal use against defective materials or workmanship as follows: Parts: Defective parts will be exchanged for new parts or comparable rebuilt parts for a period of ONE YEAR from the date of original purchase. Labor: For a period of ONE YEAR from the date of original purchase, labor will be provided free of charge by Canon USA's factory service centers or designated service facilities located in the United States. When returning Equipment under this warranty, you must pre-pay the shipping charges, and you must enclose a copy of the Bill of Sale or other proof of purchase with a complete explanation of the problem. During the ONE-YEAR warranty period, repairs will be made and the Equipment will be return-shipped to you free of charge. For repairs after the warranty period is over, you will be given an estimate of the cost of repair and an opportunity to approve or disapprove of the repair expense before it is incurred. If you approve, repairs will be made and the Equipment will be returned to you at your risk and expense. If you disapprove, we will return-ship the Equipment to you at no charge to you to an address within the United States.
This limited warranty only applies if the Equipment is used in conjunction with compatible computer equipment and compatible software, as to which items Canon USA will have no responsibility. Canon USA shall have no responsibility under this limited warranty for use of the Equipment in conjunction with incompatible peripheral equipment and/or incompatible software. Non-Canon brand peripheral equipment and software which may be distributed with, or factory loaded on, the Equipment, are sold 'AS IS' without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose. The sole warranty with respect to such non-Canon brand items is given by the manufacturer or producer thereof. If the Equipment contains a hard disk drive, Canon USA recommends that data stored on that drive be duplicated or backed up to prevent its loss in the event of failure or other malfunction of such drive.
In order to obtain warranty service, please contact the authorized Canon retail dealer from whom you purchased the Equipment or contact the CANON INFORMATION CENTER AT 855-CINE-EOS (855-246-3367) or on the internet at pro.usa.canon.com/support. You will be directed to the nearest service facility for your Equipment.
  1. Loss or damage to the Equipment due to abuse, mishandling, accident improper maintenance, use of non-Canon accessories or failure to follow operating, maintenance or environmental instructions prescribed in Canon USA's user's manual;
  2. If the Equipment is defective as a result of leaking batteries, sand, dirt or water damage;
  3. If defects or damages are caused by the use of parts or supplies (other than those sold by Canon USA) that cause damage to the Equipment or that cause abnormally frequent service calls or service problems;
  4. If defects or damages are caused by service other than Canon USA's factory service centers or authorized service facilities;
  5. Any internal modification to product hardware or firmware;
  6. Any applicable fee for Maintenance of the Equipment;
  7. If the Equipment has had its serial number or dating altered or removed.
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLIES TO THIS EQUIPMENT AFTER THE APPLICABLE PERIOD OF EXPRESS WARRANTY OR GUARANTY (EXCEPT AS MENTIONED ABOVE) GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU). CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, INCLUDING WITHOUT LIMITATION, LOSS OR CORRUPTION OF DATA STORED ON THE EQUIPMENT'S HARD DRIVE, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE EQUIPMENT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER THAN THE PURCHASE PRICE OF THE EQUIPMENT SOLD BY CANON USA AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE, MISUSE OR INABILITY TO USE THE EQUIPMENT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON USA (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
CANON U.S.A., INC
Title Canon Support | Firmware Notice: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.0.8.1.00
Advisory Type
Date 06.13.17
Title Canon Support | Firmware Notice: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.1.3.1.00
Advisory Type
Date 07.14.20
Title Canon Support | Firmware Update: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.1.0.1.00
Advisory Type
Date 12.11.17
Title Canon Support | Firmware Notice: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.1.1.1.00
Advisory Type
Date 04.04.18
Title Canon Support | Firmware Notice: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.0.9.1.00
Advisory Type
Date 08.28.17
Title Canon Support | Firmware Notice: EOS C300 Mark II / EOS C300 Mark II PL: Firmware Version 1.1.2.1.00
Advisory Type
Date 12.12.18
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
