Canon Support for EOS 5D Mark IV | Canon U.S.A., Inc.
EOS 5D Mark IV
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital, AF/AE single-lens reflex, camera |
Recording Media |
Compatible Lenses | Canon EF Lenses (excluding EF-S and EF-M lenses) |
Lens Mount | Canon EF Mount |
Type | CMOS sensor (Compatible with Dual Pixel CMOS AF) |
Pixels | Approx. 30.4 megapixels |
Pixel Unit | Approx. 5.36 µm square |
Total Pixels | Approx. 31.7 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Complies with Design rule for Camera File System 2.0 and EXIF 2.3 |
Image Format | Still Image: JPEG, RAW (14 bit Canon Original) Video: MOV (4K video: Motion JPEG; Full HD and HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC) * Variable (averaged) bit rate. |
File Size | 3:2 Aspect Ratio Large/RAW: Approx. 30.1 Megapixels (6720 x 4480) mRAW: Approx. 16.9 Megapixels (5040 x 3360) Medium: Approx. 13.3 Megapixels (4464 x 2976) Small 1/sRAW: Approx. 7.5 Megapixels (3360 x 2240) Small 2: Approx. 2.5 Megapixels (1920 x 1280) Small 3: Approx. 0.35 Megapixels (720 x 480) 4:3 Aspect Ratio Large/RAW: Approx. 26.7 Megapixels (5952 x 4480)* mRAW: Approx. 15.1 Megapixels (4480 x 3360) Medium: Approx. 11.8 Megapixels (3968 x 2976) Small 1/sRAW: Approx. 6.7 Megapixels (2976 x 2240)* Small 2: Approx. 2.2 Megapixels (1696 x 1280)* Small 3: Approx. 0.31 Megapixels (640 x 480) 16:9 Aspect Ratio Large/RAW: Approx. 25.4 Megapixels (6720 x 3776)* mRAW: Approx. 14.3 Megapixels (5040 x 2836)* Medium: Approx. 11.2 Megapixels (4464 x 2512)* Small 1/sRAW: Approx. 6.3 Megapixels (3360 x 1888)* Small 2: Approx. 2.1 Megapixels (1920 x 1080) Small 3: Approx. 0.29 Megapixels (720 x 408)* 1:1 Aspect Ratio Large/RAW: Approx. 20.1 Megapixels (4480 x 4480) mRAW: Approx. 11.3 Megapixels (3360 x 3360) Medium: Approx. 8.9 Megapixels (2976 x 2976) Small 1/sRAW: Approx. 5.0 Megapixels (2240 x 2240) Small 2: Approx. 1.6 Megapixels (1280 x 1280) Small 3: Approx. 0.23 Megapixels (480 x 480) Values for Recording Pixels are rounded off to the nearest 10,000th or 1,000th. JPEG images are generated in the set aspect ratio. RAW images are generated in [3:2], and the set aspect ratio is appended. * Inexact proportion. |
Recording Functions |
Backup Recording | N/A |
File Numbering | The following three types of file numbers can be set:
RAW + JPEG Simultaneous Recording | Possible |
Color Space | sRGB, Adobe RGB |
Picture Style |
Settings | Auto (Ambience priority/White priority), Daylight, Shade, Cloudy*, Tungsten Light, White Fluorescent Light, Flash, Custom (Custom WB), Color Temperature * Effective also in twilight and sunset. |
Auto White Balance | Option between ambience priority and white priority settings |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR (with fixed pentaprism) |
Coverage | Approx. 100% vertically and horizontally (at approx. 21mm eyepoint) |
Magnification | Approx. 0.71 |
Eye Point | Approx. 21mm (at -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0 m-1 (dpt) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror |
Viewfinder Information | Displayed with transparent liquid crystal
Depth Of Field Preview | Enabled with depth of field preview button |
Type | TTL secondary image-forming phase-difference detection system with AF-dedicated sensor |
Focusing Modes |
AF Point Selection |
Active AF Point Indicator | Displayed in viewfinder with transparent LCD and on LCD panel |
AF Assist Beam |
Metering Modes | 150,000-pixel RGB+IR metering sensor
Metering Range | EV 0-20 (at 73°F / 23°C , ISO 100) |
Exposure Control Systems | (1) Scene Intelligent Auto (2) Program AE (shiftable) (3) Shutter-priority AE (Safety shift possible) (4) Aperture-priority AE (Safety shift possible) (5) Manual exposure (6) Bulb (7) Custom shooting mode C1, C2, C3 |
Exposure Compensation | Manual: ±5 stops in 1/3 or 1/2-stop increments AEB: ±3 stops in 1/3 or 1/2-stop increments * Indicated up to ±3 stops on the LCD panel and in the viewfinder. To set exposure compensation exceeding ±3 stops, you can use Quick Control. * Live View shooting, exposure compensation can be set up to ±3 stops. |
AE Lock | (1) Auto AE lock ·In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock ·With AE lock button. (AE lock is updated each time you press the button.) Enabled in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/8000 to 30 sec., bulb (Total shutter speed range. Available range varies by shooting mode.) X-sync at 1/200 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. self-timer, 2-sec. self-timer |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings |
PC Terminal | Provided (no polarity) |
Drive Modes |
Continuous Shooting Speed | High-speed continuous shooting: Max. approx. 7.0 fps
Silent continuous shooting: Max. approx. 3.0 fps |
Shooting Modes | Still photo and video recording |
Focusing |
Metering Modes |
Metering Range | EV 0-20 (at 73°F/23°C, ISO 100) |
Grid Display |
Exposure Simulation | Possible |
Silent Shooting | Provided (Mode 1 and 2) |
File Format | MOV: 4K Video*: Motion JPEG Full HD/HD Movie: MPEG-4 AVC/H.264Variable (averaged) bit rate Audio: Linear PCM MP4: Movie: MPEG-4 AVC/H.264Variable (averaged) bit rate Audio: AAC *4K requires the following write speed requirements: CF UDMA7 (100MB/sec. or faster); SD UHS-I (90MB/sec. or higher) |
File Size | Recording Sizes: 4096 x 2160 (4K)*, 1920 x 1080 (Full HD), 1280 x 720 (HD) *4K requires the following write speed requirements: CF UDMA7 (100MB/sec. or faster); SD UHS-I (90MB/sec. or higher) |
Frame Rates | MOV: 4096 x 2160 (4K)*: 30 fps (29.97 fps) / 24 fps / 23.98 fps 1920 x 1080 (Full HD): 60 fps (59.94 fps) / 30 fps (29.97 fps) / 24 fps / 23.98 fps 1280 x 720 (HD): 120 fps (119.9 fps) MP4: 1920 x 1080 (Full HD): 60 fps (59.94 fps) / 30 fps (29.97 fps) / 24 fps / 23.98 fps *4K requires the following write speed requirements: CF UDMA7 (100MB/sec. or faster); SD UHS-I (90MB/sec. or higher) |
Canon Log | Available on Canon EOS 5D Mark IV Body with Canon Log or by upgrading the Canon EOS 5D Mark IV Body (non-Canon Log version) |
Focusing |
Exposure Compensation | Up to ±3 stops in 1/3-stop increments |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.2-inch (Screen aspect ratio of 3:2) 3.19 in./8.10cm diagonal (2.65 in./6.74cm width, 1.77 in./4.49cm height) |
Pixels | Approx. 1.62 million dots |
Coverage | Approx. 100% Viewing angle: 170° vertically and horizontally |
Brightness Control | Automatic Manually adjustable to one of seven brightness levels |
Coating | Clear View LCD II Anti-smudge coating Anti-reflection coating |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
On LCD Monitor | Electronic level indicates up to 360° roll and ±10° pitch in 1° increments. Precision has a margin of error of up to 1° for ±10°, and up to 3° for ±45°. |
In Viewfinder | Electronic level indicates up to 7.5° roll left/right and ±4° pitch in 1° increments. Precision has a margin of error of up to 1° for ±10°, and up to 3° for ±45°. |
Display Format | Single image display:
Highlight Alert | With single-image display (Info.) and single-image display, the white areas with no image data will blink. |
Items | Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback. |
Protection | Erase protection can be applied or canceled for a single image (select image), all images in a folder or all images in the card. |
Erase | Erase a single image (playback and erase image), selected images, all images in a folder or all images in a card. |
Compatible Printers | Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed. |
Printable Images |
DPOF | Compliant to DPOF Version 1.1 |
Compatible Images |
Custom Functions | 17 Custom Functions settable with the camera |
Custom Controls | Functions can be assigned to the following buttons:
Camera User Settings | Current camera settings can be registered to C1, C2 and C3 on the Mode Dial. |
My Menu Registration |
USB Terminal |
Video Out Terminal | HDMI Type C (Resolution switches automatically), CEC compatible Images can be displayed through the HDMI output and on LCD monitor at the same time. Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set. |
Battery | Battery Pack LP-E6N (or LP-E6) x 1
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 6 levels.
Power Saving | Power turns off after the set time (1, 2, 4, 8, 15 or 30 min.) of non-operation elapses.
Date/Time Battery | Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months
Start-up Time | Approx. 0.1 sec
Dimensions (W x H x D) | Approx. 5.93 x 4.58 x 2.99 in. / 150.7 x 116.4 x 75.9mm |
Weight | Approx. 31.39 oz. / 890g (Including battery, CF card and SD memory card) Approx. 28.22 oz. / 800g (Body only; without battery, card, body cap and eyecup) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Voice Memo Upgrade Service
What is the Voice Memo Upgrade Service?
We have released a new upgrade service for the EOS 5D Mark IV. This upgrade enables you to record a voice memo to a captured image.
Please note:
Canon currently offers two feature upgrades for the EOS 5D Mark IV: Voice Memo and Canon Log. Only one feature may be installed at one time. In order to install the other feature, the first must be removed.
Pricing
Model | Price* |
EOS 5D mark IV | $99.99 |
*Tax and shipping fees are NOT included
*All pricing is subject to change
Thank you, | |
Customer Support Operations | |
Canon U.S.A., Inc. | |
Contact Information for Inquiries | |
Canon Customer Support Center | |
Phone: | 1-800-OK-CANON (toll free), 1-800-652-2666 |
For additional support options: usa.canon.com/support |
