Canon Support for DP-V3010 | Canon U.S.A., Inc.
DP-V3010
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
Panel Type | IPS LCD panel |
Screen Size | 30 inch (76.1 cm) |
Aspect Ratio | 16:10 |
Resolution | 4096 x 2560 (10.5 Megapixels) |
Active display area | Approx. 25.4 x 15.9 in. / 645.1 x 403.2 mm |
Pixel Pitch | 157.5 µm / 161 ppi |
Panel Driver | 1024 gradations (10 bits for each RGB color) |
Brightness (Standard) | 48 cd/m2 (DCI), 100 cd / m2 |
Viewing Angle (Up, Down, Left, Right) | 89° (contrast ratio 10:1 or higher) |
Surface Treatment | Low-reflection glare |
Backlight Type | RGB LED, direct down type |
Power | Rated voltage: 100 - 240 V AC Rated Frequency: 50 / 60 Hz |
Power Consumption | At maximum load (including change in brightness through aging): Approx. 370 W At factory shipment: Approx. 130 W |
Environmental Conditions | Operating Temperature and humidity: 5 to 35 °C (41 - 95 °F) (20 - 85 % RH no condensation), recommended: 15 - 30 °C (59 - 86 °F) Pressure: 700 - 1060 hPa Storage / Transporting Temperature and humidity: -20 - 40 °C (-4 - 104 °F), (20 - 85 % RH no condensation) 41 - 60 °C (105 - 140 °F), (20 - 30 % RH no condensation) Pressure: 700 - 1060 hPa |
Dimensions (Width x Height x Depth) | Approx. 27.9 x 18.7 x 7.4 in. / 708 x 474 x 189 mm |
Weight | Approx. 52.8 lb. / 24kg |
Mounting Hole Pitch | VESA standard 200 x 200 mm (7.9 x 7.9 in) |
3G/HD-SDI | 8 (2 systems) BNC (75Ω) |
Display Port | 4 (1 system, version 1.1a compliant) |
HDMI | - |
3G/HD-SDI | 8(2 pass-thru systems) |
Headphone | - |
USB | 1 USB receptacle terminal Universal Serial Bus Specification Revision 2.0 compliant HS (High Speed) mode compatible. |
LAN | 1 RJ-45 terminal IEEE802.3 10BASE-TX / IEEE802.3u 100BASE-TX compliant |
Remote | - |
Supplied Accesories | Display Controller, AC Power Cord, Compact Power Adapter, AC Cable, Tip Prevention Fitting, LAN Cable, Rack Mount Bracket, Rack Mount Bracket Screw, Hex Key, Instruction Manual, Instruction Manual Disc. |
Accessories | - |
CANON PROFESSIONAL DISPLAY LIMITED WARRANTY |
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to Canon Professional Display Equipment ('the 'Equipment') accompanying this limited warranty in the Equipment's original container, when purchased in the United States. This limited warranty is only effective upon presentation of your Bill of Sale or other proof of purchase. This Limited Warranty covers all defects encountered in normal use of the Equipment and does not apply in the following cases:
This Limited Warranty does not apply to Equipment purchased outside the United States. This Limited Warranty does not apply to accessories or consumables for the Equipment, which are sold "AS IS", without warranty of any kind by Canon USA. Please retain this warranty card and your Bill of Sale as a permanent record of your purchase. This card ensures that you are contacted promptly should there be a safety inspection, modification or product recall under applicable laws or regulations. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state. |
