Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 07.01.24
File Size 4.64 MB
Date 12.05.23
File Size 198.87 KB
Date 07.27.23
File Size 2.70 MB
Date 07.01.24
File Size 20.03 MB
Date 07.01.24
File Size 2.89 MB
Date 11.28.23
File Size 938.71 KB
Date 01.16.25
File Size 2.15 MB
Date 07.01.24
File Size 408.40 KB
Color Satin Black / Titanium White
Image Sensor
Type 1.0 (1.0 in.) single-plate CMOS sensor
Total pixels: approx. 13.40 megapixels Effective pixels: approx. 8.29 megapixels (3840 x 2160)
Lens
f=8.3 - 124.5 mm, F/2.8 - 4.5, 15x optical zoom, 9-bladed iris diaphragm 35mm equivalent focal length: approx. 25.5 (W) - 382.5 mm (T)
Zoom
Optical: 15x
Digital: 20x
Advanced Zoom (FHD): 30x
Lens Configuration 14 groups of 18 elements (using 2-sided aspherical lenses and super-UD lenses)
Minimum Focusing Distance
1 cm at wide end, 60 cm across entire zooming range
Angle of View
Horizontal: 73.0 (W) - 5.7° (T)
Vertical: 45.2° (W) - 3.2° (T)
Shutter Speed
1/3 - 1/2000 sec. (specific values depend on the frame frequency)
Iris
Manual/Automatic aperture
ND Filter
3 levels: ND1 (ND: 1/4), ND2 (ND: 1/16), ND3 (ND: 1/64)
Material: Glass (with sunlight burn-in protection) Turret switched, motor-driven.
White Balance
AUTO (AWB), Set A, Set B, preset settings (daylight: 5,600 K*, tungsten lamp: 3,200 K*), color temperature setting (2,000 K - 15,000 K), Manual
Focus
Focus modes: Manual, AF-boosted MF, Continuous AF, Face Detection & Tracking, Face only AF, Eye Detection.
AF type: Dual Pixel CMOS AF, Contrast AF
Gamma
BT.709 Normal, BT.709 Wide DR, BT.709 Standard, Canon Log 3, HDR (PQ), HDR(HLG)
Image Stabilizer
Optical
Pan and Tilt
Pan operation range: Horizontal ±170°
Pan operation speed: 0.1° - 100°/sec.
Tilt operation range: Vertical -30° - +90°
Tilt operation speed: 0.1° - 100°/sec.
3G-SDI 1920 x 1080: 59.94P/59.94i/50.00P/50.00i/29.97P/25.00P/23.98P (4:2:2 10bit)
1280 x 720: 59.94p/50.00P (4:2:2 10bit)
12G-SDI
3840 x 2160: 59.94P/50.00P/29.97P/25.00P/23.98P (4:2:2 10bit)
720 x 576: 50.00i (4:2:2 10bit)
720 x 480: 59.94i (4:2:2 10bit)
HDMI 3840 x 2160: 59.94P/50.00P/29.97P/25.00P/23.98P (4:2:2 10bit)
720x576: 50.00P (4:2:2 10bit)
720x480: 59.94P (4:2:2 10bit)
IP 3840 x 2160: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 59.94fps, 50.00fps, 29.97 fps, 25.00fps, 23.98fps, 14.99 fps, 12.50fps, 11.99fps, 5.99fps, 5.00 fps (4:2:0 8 bit)
Supported Video and Control Protocols XC Protocol, RTSP/RTP, NDI|HX, RTMP/RTMPS, Standard Protocol Communication (Serial), Standard Protocol Communication (IP), FreeD, SRT
Number of Presets Max. 100 (including home position)
Communication Control
LAN, Wi-Fi, Serial, IR
Network Terminal
LAN x 1, RJ45, 1000Base-T
12G/3G-SDI OUT Terminal
BNC jack x1 12GSDI & x1 3G-SDI, 0.8 Vp-p/75
SMPTE ST 259, SMPTE ST 292, SMPTE ST 424/425, SMPTE ST2081, SMPTE ST 2082, SMPTE ST 272, SMPTE ST 299 compliant
Embedded audio, Time code (VITC/LTC)
GEN-LOCK Terminal
BNC jack x 1, 1.0 Vp-p/75
Time Code Terminal
BNC jack x 1, 1.3 Vp-p/50 or less
RS-422 Terminal
RJ45 connector x 1
Audio Input 1 / Input 2 Terminals
INPUT (3-pin jack) (pin1: shield, pin2: hot, pin3: cold), 2 sets, balanced
Sensitivity (MIC): -60 dBu (Manual volume center, full scale -18 dB)/600 /Att.: 20 dB
Sensitivity (LINE): +4 dBu (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 48 V DC (Bias resistance: 6.8 k)
Mic Terminal
3.5 mm stereo mini jack (unbalanced, plug-in power supported)
Sensitivity (MIC): -72 dBV (Manual volume center, full scale -18 dB)/1 k or more/Att.: 20 dB
Sensitivity (LINE): -10 dBV (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 2.4 V DC (Bias resistance: 2.2 k)
Media Slot
SD Card x1, microSD card slot x 1, future expansion, recording unavailable
Operating Environment Temperature: 0°C - +40°C (+32°F - +104°F)
Humidity: 10% - 90% (without condensation)
Storage Environment Temperature: 0°C - +40°C (+32°F - +104°F)
Power Supply PoE: PoE++ power supply via LAN connector (IEEE802.3bt compliant)
External power source: 12 V DC (4-pin XLR input)
Dimensions (W x H x D)
Approx. 200 x 269 x 208 mm (7.87 x 10.59 x 8.19 in.) (excluding protrusions)
Quietness
NC30 or Lower
Supported Controllers Hardware: RC-IP100
Software: Remote Camera Control Application
SUPPLIES & ACCESSORIES
