Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 07.27.23
File Size 2.34 MB
Date 07.01.24
File Size 4.64 MB
Date 12.05.23
File Size 198.87 KB
Date 07.01.24
File Size 2.57 MB
Date 07.01.24
File Size 20.03 MB
Date 11.28.23
File Size 938.71 KB
Date 07.01.24
File Size 408.40 KB
Color Options Satin black/Titanium white
Image Sensor Type 1.0 (1.0 in.) single-plate CMOS sensor
Total pixels: approx. 13.40 megapixels
Effective pixels: approx. 8.29 megapixels (3840 x 2160)
Lens f=8.3 124.5 mm, F/2.8 4.5, 15x optical zoom, 9-bladed iris diaphragm
35mm equivalent focal length: approx. 25.5 (W) 382.5 mm (T)
Zoom Digital: 20x
Optical: 15x
Lens Configuration 18 elements in 14 groups (including 2 aspheric elements)
Minimum Focusing Distance 1 cm (0.39 in.) at full wide angle, 60 cm (2.0 ft.)
throughout the zoom range
Angle of View Horizontal: 73.0 (W) 5.7° (T)
Vertical: 45.2° (W) 3.2° (T)
Shutter Speed 1/3 1/2000 sec. (specific values depend on the frame frequency and frame rate
Iris Manual/Automatic aperture
Gain -6.0 db 33.0 db
ND Filter Built-in (Off, 1/4, 1/16, 1/64), motor operated
White Balance AUTO (AWB), Set A, Set B, preset settings (daylight: 5,600 K*, tungsten lamp: 3,200 K*), color temperature setting (2,000 K 15,000 K), Manual
*Color temperatures are given for reference purposes only.
Focus Focus mode: Manual, AF-boosted MF, Continuous AF, Face AF, Tracking
AF type: Dual Pixel CMOS AF, Contrast AF
Gamma Normal1 (Standard), Normal2 (x4.0), Normal3 (BT.709), Normal4 (x5.0), Wide DR, Canon Log 3
Image Stabilizer Optical-shift
Min. Subject Illumination 3840 × 2160: Approx. 1.5 lux (shutter speed 1/30 sec., Frame Rate 29.97P, Gain 33.0 dB)
1920 ×1080: Approx. 3 lux (shutter speed 1/60 sec., Frame Rate 59.94P, Gain 33.0 dB)
Pan and Tilt Pan operation range: Horizontal ±170°
Pan operation speed: 0.1° 100°/sec.
Tilt operation range: Vertical -30° +90°
Tilt operation speed: 0.1° 100°/sec.
Frame Frequency 59.94 Hz 1920 x 1080: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 59.94 fps, 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 29.97 Hz 3840 x 2160: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 50.00 Hz 1920 x 1080: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 50.00 fps, 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 25.00 Hz 3840 x 2160: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1920 x 1080: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
1280 x 720: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
640 x 360: 25.00 fps, 12.50 fps, 5.00 fps (4:2:0 8 bit)
Frame Frequency 23.98 Hz 3840 x 2160: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
1920 x 1080: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
1280 x 720: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
640 x 360: 23.98 fps, 11.99 fps, 5.99 fps (4:2:0 8 bit)
JPEG has one fixed pattern depending on the frame frequency (format is fixed and cannot be selected) Resolution: 1280 x 720
When frame frequency is 59.94/29.97 Hz: 14.99 fps
When frame frequency is 50.00/25.00 Hz: 12.50 fps
When frame frequency is 23.98 Hz: 11.99 fps
SDI 1920 x 1080: 59.94P/59.94i, 50.00P/50.00i/25.00P, 29.97P/23.98P (4:2:2 10 bit) 1280 x 720: 59.94P, 50.00P (4:2:2 10 bit)
*Same video format required for SDI and HDMI (cannot select different formats for SDI and HDMI)
*When 3840 x 2160 is selected for HDMI, video will not be outputted to SDI.
HDMI 3840 x 2160: 29.97P, 25.00P, 23.98P (4:2:2 10 bit)
IP 3840 x 2160: 29.97 fps, 14.99 fps, 5.00 fps (4:2:0 8 bit)
*If 59.94/50.00 Hz is selected for the frame frequency, the 3840 x 2160 format cannot be selected.
*A frame rate that exceeds the frame frequency cannot be selected.
*JPEG has one pattern fixed depending on the frame frequency (format is fixed and cannot be selected)
When frame frequency is 59.94/50.00 Hz: 14.99 fps, when frame frequency is 23.98 Hz: 11.99 fps, when frame frequency is 29.97/25.00 Hz: 12.50 fps
Supported Video and Control Protocols Protocol: XC Protocol, RTSP/RTP, NDI®|HX2, SRT (Supports Adaptive Bitrate), FreeD (Supports up to 4 destinations), RTMP/RTMPS, Standard Protocol Communication (Serial), Standard Protocol Communication (IP)
Number of Presets Max. 100 (including home position)
Communication Control LAN, Wi-Fi, Serial, IR
Network Terminal LAN x 1, RJ45, 1000Base-T
3G-SDI OUT Terminal BNC jack (output only) x 1, 0.8 Vp-p/75 , unbalanced SMPTE 424, SMPTE 425, SMPTE ST 299-2 compliant Embedded audio, Time code (VITC/LTC)
GEN-LOCK Terminal BNC jack x 1, 1.0 Vp-p/75 , input only
HDMI OUT Terminal HDMI connector x 1, output only
RS-422 Terminal RJ45 connector x 1
Input 1 / Input 2 Terminals INPUT (3-pin jack) (pin1: shield, pin2: hot, pin3: cold), 2 sets, balanced
Sensitivity (MIC): -60 dBu (Manual volume center, full scale -18 dB)/600 /Att.: 20 dB
Sensitivity (LINE): +4 dBu (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 48 V DC (Bias resistance: 6.8 k)
Mic Terminal 3.5 mm stereo mini jack (unbalanced, plug-in power supported)
Sensitivity (MIC): -72 dBV (Manual volume center, full scale -18 dB)/1 k or more/Att.: 20 dB
Sensitivity (LINE): -10 dBV (Manual volume center, full scale -18 dB)/1 k or more
Supply Voltage: 2.4 V DC (Bias resistance: 2.2 k)
USB Terminal Type-A (USB 2.0) x 1
Media Slot microSD card slot x 1 (future expansion, recording unavailable)
Operating Environment Temperature: 0°C +40°C (+32°F +104°F)
Humidity: 10% 90% (without condensation)
Storage Environment Temperature: 0°C +40°C (+32°F +104°F)
Power Supply PoE: PoE+ power supply via LAN connector (IEEE802.3at compliant) PoE cannot be used
External power source: 24 V DC (using included AC adaptor)
Power Consumption PoE+ Input: Approx. 16.2 W* max. (body only)
DC Input: Approx. 18.6 W max. (body only)
*Class 4 (25.5 W required) for power supply devices
Dimensions (W x H x D) Approx. 200 x 269 x 208 mm (7.87 x 10.59 x 8.19 in.) (excluding protrusions)
Weight Approx. 4.1 kg (9.04 lb.) (body only)
Supported Controllers Hardware: RC-IP100, RC-IP1000
Software: Remote Camera Control Application
CANON U.S.A., INC. LIMITED WARRANTY
CR-N SERIES / CR-X SERIES PRODUCTS LIMITED WARRANTY
Canon U.S.A., Inc. (“Canon”) warrants (a) the Canon CR-N Series / CR-X Series products (the “Product(s)”), when sold and used in the United States, to be free from defects in workmanship and materials under normal use and service for a period of three (3) years from the date of receipt by purchaser. During such warranty period, Canon will, at its option, repair or replace a Product (1) which is returned to Canon’s designated service center, transportation charges prepaid, (2) which is proven to be defective upon Canon’s inspection and (3) which is otherwise eligible for coverage under this limited warranty. A Product repaired by Canon under this limited warranty will be returned to the purchaser’s designated location within the United States at Canon’s expense. Warranty replacement will not extend the original warranty period of a Product.
The purchaser’s cost of labor to inspect and remove a defective Product, and to install repaired or replaced Products in the field, will be purchaser’s sole responsibility and will therefore not be reimbursable by Canon. Canon will have no liability for use or performance of the Product in connection with the purchaser’s systems, even though purchaser discusses the same from time to time with Canon employees.
This warranty shall only apply if a Product is used in conjunction with compatible software, computers and other equipment, as to which items Canon will have no responsibility. This warranty does not cover Canon brand optional accessories for a Product for which separate warranties are given.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF A PRODUCT. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO A PRODUCT WILL BIND CANON. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THE PRODUCTS ARE NOT FAULT TOLERANT AND ARE NOT DESIGNED, MANUFACTURED OR INTENDED FOR USE OR RESALE AS CONTROL EQUIPMENT IN HAZARDOUS ENVIRONMENTS REQUIRING FAIL SAFE CONTROLS, SUCH AS, WITHOUT LIMITATION, THE OPERATION OF NUCLEAR FACILITIES, AIRCRAFT NAVIGATION OR AIRCRAFT COMMUNICATION SYSTEMS, AIR TRAFFIC CONTROL, LIFE SUPPORT, OR WEAPONS SYSTEMS (“HIGH RISK ACTIVITIES”). IN ADDITION TO THE OTHER DISCLAIMERS HEREIN, CANON SPECIFICALLY DISCLAIMS ANY EXPRESS OR IMPLIED WARRANTY OR CONDITION OF FITNESS FOR SUCH HIGH RISK ACTIVITIES.
This warranty shall be void and of no force or effect if a Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating instructions, or maintenance, and environmental conditions prescribed, in Canon’s operator’s manual or other documentation, (c) installation or repair by other than Canon service centers, (d) use of supplies or parts (other than those distributed by Canon) which damage a Product or cause abnormally frequent service calls or service problems, or (e) use of a Product with non-compatible software, computers, or other equipment, including the use of a Product in any system configuration not recommended in any manual distributed with a Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
CANON WILL NOT BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF A PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE A PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON. THIS WARRANTY WILL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF A PRODUCT AND STATES SUCH PURCHASER’S EXCLUSIVE REMEDY.
IT IS UNDERSTOOD AND AGREED THAT THIS LIMITED WARRANTY CAN ONLY BE ENFORCED BY PURCHASER. IT IS FURTHER UNDERSTOOD AND AGREED THAT UPON SELLING A PRODUCT, WHETHER ALONE OR IN ITS SYSTEMS, PURCHASER WILL DELIVER ITS OWN WARRANTY TO ITS CUSTOMERS. BUYER’S WARRANTY TO ITS CUSTOMERS SHALL STATE CONSPICUOUSLY THAT THE SAME IS THE SOLE AND EXCLUSIVE WARRANTY COVERING A PRODUCT.
A range of Canon USA customer technical support* options are available:
• Visit www.usa.canon.com/support for Interactive troubleshooting guidance, to obtain the latest driver downloads, hours of operation, and answers to frequently asked questions
• Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-800-423-5367
• Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, you will be provided instructions for Canon USA’s then current warranty service procedures. You may be asked for the Product serial number and/or other information pertaining to your Product.
CONDITIONS OF WARRANTY
Defective parts must be returned to Canon with all necessary documentation and will become the property of Canon.
Canon is a registered trademark of Canon Inc.
Title Firmware Notice: CR-N500: Firmware Version 1.2.0
Advisory Type
Date 08.08.22
Title Software Notice: CR-N500: Remote Camera Control Application for macOS Version 1.1.0
Advisory Type
Date 06.20.23
Title Firmware Notice: CR-N500 Firmware Version 1.5.2
Advisory Type
Date 12.06.24
Title Software Notice: Multi-Camera Management Application Version 1.0.0
Advisory Type Software Notice
Date 11.28.23
Title Software Notice: Remote Camera Control Application for Windows Version 1.5.0
Date 11.28.23
Title Software Notice: Remote Camera Control Application for macOS Version 1.2.0
Date
Title Firmware Notice: CR-N500: Firmware Version 1.3.0
Advisory Type Firmware Notice
Date 07.31.23
Title Software Notice: Auto Tracking Application Version 1.1.1
Date 04.26.24
Title Firmware Notice: CR-N500: Firmware Version 1.4.0
Date 11.28.23
Title Firmware Notice: CR-N500: Firmware Version 1.5.0
Date 07.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
