Canon Support for Color imageCLASS MF641Cw | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.24.20
File Size 2.92 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 07.20.23
File Size 405.58 KB
Date 04.24.19
File Size 408.63 KB
Date 01.31.23
File Size 2.92 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 07.20.23
File Size 146.85 KB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
Products ChromeOS
Color imageCLASS MF641Cw Spec Sheet
MAIN UNIT
CORE FUNCTIONS
Print, Copy, Scan, Send (Lite)
ITEM CODE
3102C019
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
250 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 1-sheet Stack Bypass
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
75 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Color, Thick, Coated,
Label, Letter, Envelope (10 Envelopes)
Manual Feed Slot: Thin, Plain, Recycled, Color, Thick, Coated,
Label, Letter, Envelope (1 Envelope)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
Manual Feed Slot: Letter, Legal, Statement, Executive
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
Manual Feed Slot: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
WARM-UP TIME
From Power On: 13 Seconds or Less;
From Sleep Mode: 6.1 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 16.9" x 16.5" x 14.3" (429 mm x 419 mm x 363 mm)
Box: 23.4" x 23.0" x 21.3" (594 mm x 584 mm x 541 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 17.8" x 33.3" x 26.8" (451 mm x 847 mm x 681 mm)
WEIGHT3
Unit: Approx. 39.6 lb. (18 kg)
Boxed Weight: Approx. 53.9 lb.(25 kg)
SUPPORTED OS
Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later)
WHAT COMES IN THE BOX
MF641Cw Product, Cartridge 054 CMY Starter: 680 Yield/Black Standard: 1,500 Yield, Power Cord, Starter Guide, User Software DVD-ROM, Warranty Card5
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED4
Up to 18 ppm (Letter/Legal)
FIRST PRINT-OUT TIME
Approx. 10.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
150 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
Platen: 11.2 seconds/13.1 seconds (BW/Color)
COPY RESOLUTION (dpi)
600 x 600
COPY SIZE
Platen: Up to Letter
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
COPY FEATURES
Paper Setting, Favorite Setting, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPE
Color Contact Image Sensor
SCAN SIZE
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
ScanGear MF for TWAIN, and WIA
SCAN RESOLUTION (dpi)
300 x 600, 600 x 600
SCAN TO MOBILE DEVICES
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
Email/Internet FAX (SMTP), SMB, FTP
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION (dpi)
600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUNICATION PROTOCOL
File: FTP, SMB
Email/iFax: SMTP, POP3, iFax (Simple)
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 900 W
Standby: Approx. 10.5 W
Sleep Mode: Approx. 0.8 W
Typical Electricity Consumption (TEC) Rating: 0.19 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver2
FOOTNOTES
1 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
2 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
3 Includes consumables.
4 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
5 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Regarding Vulnerability Against Buffer Overflow for Canon Laser Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 11.18.22
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Vulnerability Mitigation/Remediation for Small Office Multifunctional Printers and Laser Printers
Date 03.15.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
