Canon Support for CanoScan FS4000US | Canon U.S.A., Inc.
CanoScan FS4000US
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 7.73 MB
Scanner Type Desktop Film Scanner
Scanning Element Charged-Coupled Device 3-line color image sensor
Light Source Cold cathode mercury fluorescent lamp
Scanning Speed (Positives, at 500dpi/1000dpi/200dpi/4000dpi)*: 35mm: 6/12/24/48 seconds ; Advanced Photo System (IX240): 4/9/18/36 seconds
Scanning Mode 14-bit scanning for each color (RGB)/16-bit**, 8-bit output
Optical Density Range 3.4 in 24-bit mode; 4.2 in 42-bit mode
Max. Film Size 35mm: Color (Positives/Negatives), Monochrome (Positives/Negatives), Mounted slide film***, Filmstrip ****; Advanced Photo System (IX240): Color (Positives/Negatives), Monochrome (Negatives), Mounted slide film, Cartridge *****
Scanning Pixels 35mm: 3,780 X 5,669 pixels; Advanced Photo System (IX240): 2,457 X 4,315 pixels
Scanning Area 35mm: 24.0 x 36.0 mm; Advanced Photo System (IX240): 15.6 x 27.4 mm
Interface USB1.1/SCSI-2; Connectors: USB connector x 1slot/SCSI half-pitch 50-pin (Use interface switch on bottom panel.)
Dimensions (W x D x H) 92 x 144 x 368 mm (3.6 x 5.7 x 14.5 inches)
Weight 2,400g (5.3lb.)
OS Compatibility Windows 98/98SE/2000 Professional/Me, Mac OS 8.6/9
Power Source 100-240 Volts AC, 50/60Hz (switches automatically)
Max. Power Consumption Operating: 35W, Stand by: 12W
* Scanning time only; data transfer and image showing times are not included. Scanning speed depends on the film.
** 16-bit output will be available in case of connecting with its supported software, such as Adobe Photoshop LE to be bundled.
*** With Slide Mount Holder bundled.
**** With 35mm Filmstrip Holder bundled.
***** With IX240 Film Cartridge Holder bundled.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
