Canon Support for CanoScan 5000F | Canon U.S.A., Inc.
CanoScan 5000F
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 2.09 MB
Date 04.01.07
File Size 2.70 MB
Date 12.27.11
File Size 2.57 MB
Scanner Type Flatbed, color and monochrome
Scanning Element Charge-Coupled Device (CCD)
Light Source Cold Cathode Fluorescent Lamp
Scanning Mode 48-bit internal/external, Grayscale - 16-bit internal/8-bit external, Black & White, Text Enhanced
Max. Document Size 8.5" x 11.7"; Film - 35mm x 3 frames (negatives), 35mm x 2 frames (mounted slides)
Interface USB 2.0 Hi-Speed
Dimensions (W x D x H) 10.9" x 20.0" x 4.2"
Weight 7.5 lbs.
OS Compatibility Windows&reg; 98/2000/Me/XP, Mac&reg; OS 9.0 - 9.x, Mac OS X v10.1 or later (Classic mode), Mac OS X v10.1.3 (Native mode)
Software CanoScan Setup CD-ROM****** Including: ScanGear&reg; CS (Windows/Mac), CanoScan Toolbox (Windows/Mac), ArcSoft&reg; PhotoStudio&reg; (Windows/Mac), ArcSoft PhotoBase&#153; (Windows/Mac), ScanSoft&reg; OmniPage&reg; SE OCR&#153; (Windows/Mac OS 9.1 to 9.x, Mac OS X Classic mode), NewSoft&reg; Presto! PageManager&reg; (Windows only) and NewSoft Presto! BizCard&reg; (30-day trial version, Windows only)
Power Source 120V AC, 60 Hz
Max. Power Consumption 14.8 W (5.6 W standby)
Operating Temperature: 50&deg; - 95&deg;
Operating Humidity: 20% - 80% RH
Warranty 1-year limited warranty with InstantExchange warranty program (conditions and restrictions apply, see www.canontechsupport.com for details)
&#134; Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
* Based on Canon Inc. testing, using Pentium 4, 1.7 GHz, 256MB RAM, using Adaptec DUO CONNECT. Scanning an approx. 8.5" x 11" image at 600 dpi. Results may vary.
** Windows users only.
*** Available only when using 2400 or less dpi.
**** Systems with Pentium&reg; III or higher, Celeron&reg; (566MHz or higher), AMD: Athlon&#153;, Athlon MP, Athlon XP or Duron are recommended for optimal performance.
***** ScanGear CS driver (Plug-in compatible) and CanoScan Toolbox, quick scanning utility are available in Mac OS X native mode.
****** System requirements vary by application.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
