Service Notice: Regarding Vulnerability Measure Against Buffer Overflow for Laser Printers and Small Office Multifunctional Printers
Updated: February 28, 2025
Canon U.S.A., Inc. has recently become aware of potential multiple buffer overflow vulnerabilities in the Canon Laser Printers and Small Office Multifunctional Printers listed under "Affected Models" below.
If the product is connected directly to the Internet without using a wired or Wi-Fi router, a third party could potentially execute arbitrary code or the product could be subjected to a Denial-of-Service (DoS) attack.
Listed below are the CVE numbers associated with the potential Buffer Overflow issue:
CVE-2024-12647
CVE-2024-12648
CVE-2024-12649
Affected Models:
imageCLASS MF Series
MF455DW/MF453DW/MF452DW/MF451DW
MF656CDW/MF654CDW/MF653CDW/MF652CW
MF1238 II
MF1643iF II/MF1643i II
imageCLASS LBP Series
LBP237DW/LBP236DW
LBP632CDW/LBP633CDW
LBP1238 II
Note: If we determine that additional products could potentially be impacted by this matter, we will issue an updated Service Notice.
Mitigation/Remediation:
We recommend that our customers set a private IP address for the products and create a network environment with a firewall or wired/Wi-Fi router that can restrict network access.
Please refer here for more details on securing products when connecting to a network.
In addition, we advise that our customers install the latest firmware available using the instructions below.
To update the firmware via the Internet, take the following steps from the printer unit:
<Touch Panel Model>
Select [Update Firmware] on the Home screen.
When a license screen appears, select [Accept].
Select [OK].
<Black and White LCD Model>
Select [Menu] on the Home screen.
Select [Management Settings].
Select [Remote UI Settings/Update Firmware] > [Update Firmware].
Select [Via Internet].
Check the message and select [Yes].
When a license screen appears, press [OK].
Select [OK].
For more information, please refer to the "Updating the Firmware" section in the product’s User Manual.
Thank you,
Customer Support
Canon U.S.A., Inc.
Get personalized support via My Canon Account. Access your account, or create a new account, click here to get started.
