Firmware Notice: EOS R: Firmware Version 1.6.0
Firmware Version 1.6.0 incorporates the following improvements and fixes:
- Support for the RF 85mm F1.2L USM DS lens has been added.
- Corrects a phenomenon in which the function or setting value assigned to the control ring may change when the control ring is operated in Eco mode.
- Corrects a phenomenon in which the camera may stop operating properly during “auto transfer” when using Camera Connect with a Wi-Fi connection.
- Corrects a phenomenon in which high-speed synchronization with use of an external flash may not operate properly depending on the camera’s setting for C.Fn2 “Set shutter speed range”.
Firmware Version 1.6.0 is for cameras with firmware up to Version 1.4.0. If the camera's firmware is already Version 1.6.0, it is not necessary to update the firmware.
Once the EOS R is updated to Version 1.6.0 (or later), it cannot be restored to a previous firmware version (Version 1.0.0 to 1.4.0).
Support
Download Firmware Version 1.6.0 for the EOS R.
This firmware update is for camera equipped with older firmware version. If the camera firmware is already the latest version (Version 1.4.0), firmware update is unnecessary.
If you have not already done so, please register the EOS R. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc
Contact Information for Inquiries | |
Canon Customer Support Center | |
Phone: | 1-800-OK-CANON 1-800-652-2666 |
TDD: | 1-855-270-3277 |
Email: | carecenter@cits.canon.com |
Support options and hours of operation: www.usa.canon.com/support |
