Firmware Notice: Mount Adapter EF-EOS R 0.71x: Firmware Version 1.3.0
Firmware Version 1.3.0 incorporates the following enhancement:
Firmware Version 1.3.0 adds full function support for the 7 models of EF cinema lenses and 6 models of EF lenses listed below when used with the EOS C70.
EF Cinema Lenses1. CN-E14mm T3.1 L F
2. CN-E20mm T1.5 L F
3. CN-E24mm T1.5 L F
4. CN-E35mm T1.5 L F
5. CN-E50mm T1.3 L F
6. CN-E85mm T1.3 L F
7. CN-E135mm T2.2 L F
EF Lenses
1. EF 14mm f/2.8L II USM
2. EF 24mm f/1.4L II USM
3. EF 35mm f/1.4L II USM
4. EF 50mm f/1.2L USM
5. EF 85mm f/1.2L II USM
6. EF 135mm f/2L USM
Note: When this mount adapter is attached to the above lenses, the amount of peripheral light may decrease significantly.
(Supported lenses: Firmware version 1.2.0 or earlier)
EF 16-35mm f/2.8L II USM
EF 16-35mm f/2.8L III USM
EF 16-35mm f/4L IS USM
EF 24-70mm f/2.8L II USM
EF 24-105mm f/4L IS USM
EF 24-105mm f/4L IS II USM
EF 70-200mm f/2.8L IS II USM
EF 70-200mm f/2.8L IS III USM
EF 70-200mm f/4L IS USM
EF 70-200mm f/4L IS II USM
Caution:
- Firmware version 1.3.0 is the updated firmware version for mount adapter EF-EOS R 0.71x version 1.2.0. If the mount adapter's firmware is already version 1.3.0, it is not necessary to update the firmware. You can check the firmware version of the mount adapter from the camera menu. Refer to the camera instruction manual for how to check the version. Once the camera is updated to the latest version, it cannot be restored to the previous version.
- Please prepare a memory card supported by the camera. Please see the camera's instruction manual for details on which memory cards are supported by each camera model.
- It is also necessary to update the firmware of the camera body of the EOS C70.
Support
Download Firmware Version 1.3.0 for the Mount Adapter EF-EOS R 0.71x.
If you have not already done so, please register the Mount Adapter EF-EOS R 0.71x. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-855-CINE-EOS (toll free) / 1-855-246-3367
TDD: 1-855-270-3277
Email: Canon4K@cits.canon.com
For additional support options: usa.canon.com/support
