Firmware Notice: DP-V2420: Firmware Version 1.2.1
Firmware Version 1.2.1 incorporates the following improvements:
- A function has been added that automatically switches the picture quality settings in accordance with the video resolution (4K/2K) and the metadata - Colorimetry bit of the video payload ID, cinema camera type (CINEMA EOS SYSTEM/ARRI/Panasonic), and HDMI. This enables more practical and efficient operation in environments that use both HDR and SDR.
- A function has been added that displays the brightness values*1 or RGB values of the input video of the specified pixel position. This enables to check the subject brightness in greater detail.
- A function has been added that displays the peak and average brightness values*1, or the peak and average gradation values as well as the transition in these values for the entire input video picture (frame). This enables to visually check changes in brightness during video production.
- A comparison display function has been added that enables HDR/SDR comparison display, and CDL/User LUT ON/OFF comparison. This enables left-right picture quality comparison display with the press of a single button.
- A function has been added that colors areas which are over the specified range. The rest of the image is shown in monochrome. This enables to visually check the brightness level during HDR shooting.
- A function has been added to “False Color” that enables users to adjust the boundary positions of the brightness range.
- A function has been added to “2020 Outside of Gamut View” that colors areas outside the native color gamut of the panel.
- PLUGE and Color Bar test pattern images for HDR signals have been added to “Test Pattern”.
- A function has been added for remotely controlling the display using a Web browser*2. This enables to use a Computer, tablet or other device to check and manipulate the displayed video and settings.
- Functions “2020 PQ to 2020 SDR”, “2020 PQ to 709 SDR”, and “2020 HLG to 709 HLG” have been added to the “CDL/User LUT”. This enables display of PQ signals converted to SDR characteristics and display with the PQ/HLG signal color gamut converted to BT.709.
- The ARRI cinema camera LUTs “ARRI (Rec2100-PQ-1K-100)” and “ARRI (Rec2100-HLG-1K-200)” and the Panasonic cinema camera LUT “VARICAM (V-Log to V-709)” have been added to “User LUT”.
- “Preset Log 1”, “Preset Log 2”, “ARRI (Rec2100-PQ-1K-100)” and “ARRI (Rec2100-HLG-1K-200)” scale display have been added to “Wave Form Monitor”.
- A function has been added to “Wave Form Monitor” so that colors appear on areas outside the ranges set by “Color Range” and “HDR Range”. This allows for an easy check for the areas outside these ranges.
- A waveform monitor can now be displayed in both the left and right pictures during Multi View (Dual) display.
- A brightness adjustment function has been added to “Wave Form Monitor”.
- The system gamma can now be adjusted between 1.000 and 1.500 when “Gamma/EOTF” is set to “Hybrid Log-Gamma.
- The auto setting operation in “Color Range” has been changed to “Full” when “Gamma /EOTF” is set to “Preset Log 1” or “Preset Log 2”.
- A “D65-Custom” setting has been added to “Color Temperature” to enable fine adjustment of the D65 color temperature.
- The operation when “Color Range” is set to “Limited” has been enhanced so that over-white and under-black areas can be displayed.
- An anamorphic image can now be zoomed in the proper ratio.
- “Gray” color has been added to the line display color setting, and “Half” brightness to the brightness setting have been added in the “Aspect Marker/Safety Zone Marker 1/Safety Zone Marker 2/Area Marker/Center Marker/Grid Marker” settings. This enables dark display during HDR display.
- A display size setting has been added to “Center Marker /Audio Level Meter”.
- Horizontal display position adjustment, brightness adjustment, and VITC/LTC display ON/OFF settings have been added to “Time Code”.
- A save format setting has been added so that JPEG format capture is now possible in addition to the previous bitmap format.
- HDR/SDR comparison display is now possible when “Peak Luminance Control” is set to “On”.
- Other UI and operation performance enhancements have also been made.
*1: Only when “Gamma /EOTF” is set to “SMPTE ST 2084 (PQ)/Hybrid Log-Gamma”. (Not supported when
“Gamma /EOTF” is set to “Hybrid Log-Gamma RGB”.)
*2: A Wi-Fi adapter is required when using Wi-Fi.
Firmware Version 1.2.1 is for the DP-V2420 4K Reference Display running Firmware Version 1.1. If the Reference Display's firmware is already version 1.2.1, it is not necessary to update the firmware.
Preparations for updating the firmware
It is recommended that current settings are exported before attempting to update the firmware. Once the firmware is updated, settings can be imported back to the display. The downloaded folder contains the new firmware. (Filename: "update_dpv2420.rom", file size: 24,748,940 bytes)It also contains the firmware update procedure document (multilingual PDF file in following languages: Japanese, English, French, German and Chinese (simplified characters).Before proceeding to update the firmware, please read the firmware update procedure document.
The following items are required to perform the firmware update:
- Display unit
- Personal computer
- USB memory (FAT16 or FAT32)
- Firmware (The downloaded file)
Support
Download Firmware Version 1.2.1 for the DP-V2420.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
If you have not already done so, please register your DP-V2420. By registering, we will be able to notify you via email about future service upgrades.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries | |
Canon Customer Support Center | |
Phone: | 1-855-4K-CANON |
1-855-452-2666 | |
TTD: | 1-866-251-3752 |
Email: | Canon4K@cits.canon.com |
Support options and hours of operation: www.usa.canon.com/support |
