REALiS WX6000 Pro AV, REALiS WX6000D Pro AV, REALiS SX6000 Pro AV, REALiS SX6000D Pro AV Firmware Update
Update
Thank you for using Canon products.
If the Canon WX6000 or SX6000 projector meets the criteria listed in the table below, it may be affected by the phenomena described below. If so, please contact us using the contact information listed at the bottom of this page and will update the firmware of the projector to address these phenomena.
We offer our most sincere apologies to customers using these products who have been inconvenienced by this issue.
The following phenomena have been confirmed on some Canon WX6000/SX6000 projectors.
Phenomenon
The following conditions, when met in the following order, will cause the projector not to respond when using a LAN communication method
- The network function is activated.
- The projector has been connected to a power source for 16 days or more.
The following conditions, when met in the following order, and when accessed from the projector menu/buttons, or the remote control, will cause the projector not to respond.
- The menu is displayed on the screen.
Products
The models with the firmware version listed below may be affected by the phenomena listed above and are eligible for the firmware update.
Model Name |
Firmware Version |
WX6000 | 01.000100 |
SX6000 | 01.000100 |
How to Identify Affected Products:
You can check the firmware version with the following procedure. The example below is from the SX6000 menu. Please use the same procedure for other affected projector models.
Details
Make a projection and display the menu.
1.Press the MENU button on the projector or on the remote controller to open the menu screen.
2.Use the right cross-directional key (►) to move to the Information tab.
3.Check the firmware version in the Firmware field. (The following menu is displayed when the Network function is set to on.)
Support
Affected products will be inspected and repaired free of charge. If you own one of the affected products, please contact our Customer Support Center. This information is for residents of the United States and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region.
Please register the SX6000 Pro AV,SX6000D Pro AV, WX6000 Pro AV, and WX6000 D Pro AV. By registering, we will be able to notify you via email when future service updates are available.
Thank you,
Customer Support Operations
Canon U.S.A., Inc
Contact Information for Inquiries
Phone: 1-800-OK-CANON
1-800-652-2666
TDD: 1-866-251-3752
Email: carecenter@cits.canon.com
Support options and hours of operation: www.usa.canon.com/support
