Firmware Notice: XF605: Firmware Version 1.0.3.1
Firmware Version 1.0.3.1 incorporates the following enhancements:
1. Adds support for the Canon Multi-Camera Control.
2. Adds support for the Remote Camera Controller RC-IP1000.
3. Adds SRT protocol for IP streaming protocol.
4. Enables to select 1920×1080 59.94i/50i 25Mbps format when in XF-AVC recording.
5. Adds [Chunk Recording] function. Adds the ability to record proxy files in timed segments (30 seconds / 1 min / 2 min) when Main and Proxy recording is selected.
Simultaneously records a clip that split by time, suitable for automatic transfer to SD card B while the main clip is recorded to SD card A.
6. Adds the function to automatically transfer chunk recording clip via Content Transfer Mobile.
7. Enhances Clear Scan resolution.
8. Enables to change WFM size.
9. Enables to change Vector scope gain by touch.
10. Enables to change WFM/Vector scope transparency.
11. Improves Vector scope.
- Changes to display [BT.2020] in the frame when the color space is set to BT.2020.
- Changes to always display the target color name.
12. Adds [Canon 709 / BT.709] to the Gamma/Color Space in Custom Picture setting.
13. Adds [CMT 709] in LUT and View Assistance, Sub Rec Color Conversion.
14. Adds [G Gain] in White Balance in Custom Picture settings.
15. Adds [_Proxy] option to XF-AVC proxy media name.
16. Adds the ability to select multiple files from a playlist for indexing and continuous playback.
17. Adds [LCD/VF] in Peaking and Zebra settings.
- The default setting of the [All] has been changed from [LCD/VF] to prevent unintended effects from being applied to HDMI/SDI output.
Caution:
- Please use a commercially available SD/SDHC/SDXC memory card that is 512MB or greater to perform the firmware update.
- Firmware version 1.0.3.1 is for updating cameras running firmware version 1.0.0.1 - 1.0.2.1. If your camera's firmware is already version 1.0.3.1, it is not necessary to update the firmware. Once the camera is updated to the latest version, it cannot be restored to a previous version.
- Please refrain from loading menu settings generated using the most recent firmware version to a product running an old firmware version, as doing so may affect camera operations.
Support
Download Firmware Version 1.0.3.1 for the XF605.
To help obtain optimal performance of this camera, we recommend that you download and install the most recent versions of Canon software and the XF605 Advanced User Guide (PDF).
If you have not already done so, please register the XF605. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-800-OK-CANON / 1-800-652-2666
TDD: 1-855-270-3277
Support options and hours of operation: www.usa.canon.com/support
